33" with 3" lift
Because i want the change the front bumper + add bushwaker, etc
Sorry, i dont want to put bushacker :anon:
You might want to plan out your lift a little better. It sounds like you're going about this quickly without doing much research and taking the time to put it together properly.
I'm still acquiring pieces and I started last November but was doing research back in July. I have one more piece before everything is done and ready to go onto the Jeep. Just need the time.
I am 3.5" with 32s and I definitely had to trim the front. I could not turn real sharp with out hitting the back part of the fender.
By hearing these guys say you will have to trim , I would listen. I bumped up to 235's at stock height and until i put the AAL's in the back, they rubbed like crazy on a 15x7 wheel w/4.75" BS.
I wasn't questioning 11.5 " tires with 3.5" back spacing, it was 10.5" on 5" backspacing.
Dude, I have 32x11.5" tires and a 4.5" lift with spacers up front and I still rub my trimmed fenders pretty bad. Only bumpstops up front are the ones from RE, I have to stack some pucks as well.
