31x10.5s on stock wheels?
Yea, you can put 31x10.50 on the stock wheels, that's what i run with 4.5" lift, they do look really small with that much lift, but with 3 you be perfect. Stock rim i think is 7" wide so tires only 4.5" wider then the rim, it would work good. I think that most of the people who got 31's are running stock rims, it's when you want to go to 33x12.50's you got to get 8" or 10" wide rim.
31x10.5R15 TrXus MTs on stock 15x7 wheels with a 3" lift and slightly trimmed fenders/no flares. LCA rubbing, as was stated before, i just added washers behind the steering stops, cured.
Make sure you have the 7" wheels. Some came with 6"; my '90 as an example. You can check the build sheet if you have one.
