I have done some searching and have decided to try and tackle a front 3 Link setup when the weather gets a little cooler. One thing I have noticed that a lot guys building their systems run the upper link on the passenger side while some of the kits you can buy run it on the driver side with a bridge over the diff. Is one side better than the other? What are the benfits of each and what side is more simplistic to accomplish. I would rather not have to do unnessecary work like move the exhuast and trac bar if i don't have to. I will be building my own frame stiffeners, crossmember, etc. I have seen a lot of built jeeps done on pass side. But trusted companies such as clayton run driver side. I just want to get experienced opinions and advice to ad to my database before I do this. I want to build a solid system that is correct and safe. Any advice or input would be very helpful .
