- Patterson, Ca
Either that is a 54" tire in the pic, or it's more like 2' off the ground than 4'. The bottom of the drivers front is about even with the center of the passenger hub. Assuming a 31" tire that would be 15.5" off the ground?
Wow. Just wow. I run a LA 4 link and can get about 4' of travel out of the front end before the one of the rear tires lifts off of the ground.
"Bind"... I do not think so as long as the links use high misalignment spherical rod ends. If what was under discussion was links using the stock rubber type of joint, then yes it will bind dop to the joint, not the number of links.
And yes, it is my rig that SolarBell is referring to........
Plus, the rear antisawy bar had not yet been removed when the photos were taken.
A couple of shots taken right after the lift was in but before the rear sway was removed:
[/URL][/IMG]![]()
[/URL][/IMG]![]()
Bind?
I may be wrong, but I think a rubber bushing is ultimately a source of bind rather than deflection...
The bind point in a 4-link is going to be dictated by joints (misalignment tolerance) and link length. A 4-link will bind, sure, but it may bind well past the point where other things limit the travel. Like shocks, fenders, bump stops (hopefully), oil pan clearance, whathaveyou.
A 3-link might not bind but it might not be relevant in the real world.
Some trucks, newer Dodge comes to mind, do run a 3 link - but links and mounts are built for it. You shouldn't just take a control arm off a stock XJ and call it a three link...
That said, I think you could look at the clamp strength & shear strength of a single large-ass bolt & see for yourself if it's better than the 2 10mm bolts the factory XJ uses. Just make sure you are taking into account that those 2 10mm bolts are hard as holy hell - spec'ed at 65 foot lbs for the nut vs the usual 37 for a grade 8.8 10x1.5 bolt.
All this being said... I'm not an engineer and there's bound to be one or two people who know better and maybe one who disagrees with me here. Hopefully some of this was useful to somebody though...
What? Are you basically arguing that 4 is better than 3 just because more links must equal stronger suspension?
So the bushing needs to deflect front-back? Side-side is fixed by the bolt whichever joint you run, twisting the bushing runs out of misalignment much quicker than a hard joint. I'm just trying to follow what you are saying, not intending to argue.
