3" iron blocks
Like for leafspring spacers for the back?
Go to colorado Iron and metal. They will cut what ever you need. They might even just give it to you if it's not much. They're right off mulberry by the hunt club. 482-7707
MJs are sprung under but yes if you've converted to spring over I wouldn't ever do more than an inch lift with blocks on stock springs.
I wouldn't do any blocks honestly, I get spring wrap on mine and it's still sprung under.
traction bar would be a real good idea.
if you're looking for 3" skyjacker makes an AAL for the Mj packs, I have it, it's not horrible, and would stiffen up the pack as well to resist the spring wrap.
87manche said:
unless you've gone spring over in the rear, blocks will lower an MJ.
Exactly. I know all about the wrap issues, I just have to set the ride height and then do what's necessary to get rid of the windup. Might take a lot with over 500 ft/lb, too. I'll probably go 4 link/ 9" before long so this is relatively temporary.
So, does anyone local have any around, or do I need to make them?
