Good Afternoon Hive!
I have searched the forum a bit and ran through a lot of checks. This is where I stand.
2001 XJ Sport 4.0L Automatic. My Nieces Car.
Driving slow speed in parking lot. Car dies. Crank, no start condition.
In my garage now. Cranks, no start. I can hear fuel pump prime. Fuel at Schrader valve on fuel rail. I used Starter fluid in throttle body while cranking, not even a stumble.
Screams no spark.
Replaced CPS no joy
Tested coil packs, got a fault in 3,4 coil, replaced coil packs, no joy
Checked all fuses & Relays no joy
Swapped a PCM from my 2000 XJ, no joy.
Here is the fun part, swapped 2001 PCM into my 2000 XJ, starts & Dies after 3 seconds (SKIMS right??) but looks like PCM out of 2001 XJ is not the no start issue! Yea!
Put original PCM back into my 2000 XJ, Starts & Dies after 3 seconds. I appear to have killed the SKIMS coding in the PCM?
So I now have 2 non running XJ's in my driveway......
ANY insight into EITHER XJ issue would be HUGE!!!!!
Screams no spark.
Replaced CPS no joy
