2001 tach signal source?
BillR
Toy Jeep driver!
Flagstaff, AZ
On an '01, does the tach run off the CPS in the distributor hole? Is there another "CPS" on the bellhousing on mine?
I was told I had a CRANK position sensor AND a CAM position sensor. This doesn't make sense to me, since the cam and crank are hooked together by the timing chain.
Please fill me in....
TIA! :wave1:
They all have both a crank position sensor and a cam position sensor. However, I don't know what triggers the tach in the OBD-II models.
