2000 XJ Sport Intermittent Loss of 4th Gear/OD. P0705. Cycling power brings back OD.
Papasox
Hi all.
Own a 2000 XJ Sport 4.0L with AW4 and 173k miles. (Automatic)
I’ve had the P0705 code for as long as I’ve owned the car (since 115k). Never really had any problems with it though. Changed the NSS like 5 years ago and the code remained. Never thought much of it.
Recently I’ve lost the ability to get into OD while driving at highway speeds. Around 40-50 mph my CEL will come on (if it’s not already on) and my car will not shift into 4th gear. It’ll stay in 3rd (3000 rpm at ~70mph). If I pull over and turn my car off, and back on. I’ll get back into OD at highway speeds like normal.
The NSS has also been recently replaced again. Thinking of bringing it to a transmission shop although I don’t think anything is mechanically wrong with the transmission, other than maybe the torque converter? Maybe the solenoids?
I’ve also read it could be the TPS, TV cable, and or a blown fuse…
Recently been feeling tiny “jumps” every now and then at highway speeds. They’re few and far between and sometimes I can’t tell if it’s the road or not.
I don’t really have the ability to work on my vehicle just given my living situation, and any threads I’ve found about this problem never have a clarified solution. Pls send help!
Should I even bring it to a transmission shop?
I had this bookmarked that has a lot of helpful info:
https://naxja.org/threads/98-xj-p0700-and-p0705.1161762/
My 98 XJ had a rebuilt transmission already, so I was less suspect of the transmission itself.
I had a P0700 and (eventually) a P0740.
My original NSS had a worn down contact area internally (rather than just being dirty inside), so I replaced it.
Note you can check each gear function on the connector and it may require finer adjustment (or even making the mounting hole a little larger as in linked thread) so the computer is "seeing" each gear position correctly.
I unplugged the 3 big connectors on the firewall to be sure clean and in good condition and this seemed to keep P0700 at bay awhile.
I changed the brake switch because I wanted a spare, but this wasn't my problem.
The plunger does adjust, so it's important that it's positioned properly.
I wasn't having bucking or much noticeable symptoms driving when I started getting P0740 code.
The solenoid resistance checked OK though the connector.
Eventually I decided it must be weak or intermittent and replaced solenoids. Worked fine awhile, then new 1-2 solenoid went out.
Tried a different set of solenoids and those have all been working well for awhile now. 👍
If the bolt won't easily go through the solenoid bracket, enlarge the hole slightly and don't force it.
Don't forget to be sure all harness grounds are good too!
Standard thing to do on ALL Aisin transmissions with any shifting issue is a simple drain and fill with specified fluid. For the XJ it’s Valvoline DextronIII/Mercon at Walmart, $22 for four quarts. Need one wrench to drain, refill though dipstick, takes about 3.5 quarts, probably a dozen YouTube videos on how to do it. 50% of the time it fixes the issue.
