unclemonte
- N E Ohio
Can anything be done to improve performance of the 2.5 ? This is a 96 XJ and its stock. Im brand new at this so pardon my ignorance. Can it be replaced with a 4.0 ?
Yes it can be replaced by a 4.0. Anything is possible given enough money and timeunclemonte said:Can anything be done to improve performance of the 2.5 ? This is a 96 XJ and its stock. Im brand new at this so pardon my ignorance. Can it be replaced with a 4.0 ?
j99xj said:I wouldn't bother with a 4.0 swap. Its much easier to just buy one that came with a 4.0 stock. They are very common and affordable in all parts of the country.
old_man said:The early XJ's didn't even have a 4.0L option. As for bigger TB. If you don't go headers, and some head work along with a cam, it is doubtful the bigger TB will yield you much. For wheeling, adding a 9 pound flywheel weight made the biggest improvement.
I loved my 2.5L and its 25+mpg, but here in the mountains, it simply didn't have the lungs for the passes. I never was at a loss for power on the trails. I do know that when I went to the stroker, I sure started busting a lot more axles. I lost 2 within 10 minutes of eachother on simple obstacles.
