1999 Cherokee Sport Part Out
K5Matt
Bremen, Indiana
Picked up this Jeep a couple weeks ago.
4.0, auto, 242, d30/8.25, 143k. Engine cranks, but won't start. The dreaded 'no bus' comes up on the cluster. ECU is badly damaged, assuming that is what the problem is.
Front driveshaft has a dent and a busted u-joint.
Front two tires are junk(RF has a bulge), has 3 good rims. Rear tires are ok.
Front axle is probably bent, hard to tell.
Let me know what you need! PM, post, or text 574-209-zerofourfiveseven.
Front end parts are garbage, as is headlight harness, etc.
Passenger side front fender has some minor damage, RF door is in good shape, but window is broken. Has some rust too, but still a usable part.
Interior isn't too bad.
Engine has a busted power steering pulley, lower air box is broken.
Sold the left side seat belts.
Sold the following: driver's door trim, left side seat belts, hvac controller, master window switch, rear driveshaft, transfer case, seats, rear axle.
Sold the following: driver's door trim, left side seat belts, hvac controller, master window switch, rear driveshaft, transfer case, seats, rear axle, tail lights, rear bumper corners, engine, gauge cluster.
how about the b-pillar weather strip/moulding for the rear doors(its goes on the front edge of the rear doors to 'fill the gap' between the rear edge of the front door and the leading edge of the rear door. I need the driver side, but if both sides are available a spare would be nice.
