setsdw96xj
- Tennessee
I have a 1996 Jeep Cherokee XJ rock crawler for sale located in Cookeville, TN. It has 4" of lift, and 35x12.50x15 BFG AT's with less than 5,000 miles on them.
Everything works great and it runs great. I just never get to go off-road and I need something that gets better gas mileage. Open to offers and trades on other vehicles of equal
value. Email me with questions [email protected]
Now for the details,
Front Axle is a High Pinion Dana 30 That is trussed
Chromolly inner and outer axle shafts. (spares with hubs will be included)
It has 4.88 gears, Spartan locker in the front, New front hubs,New Tie rod ends,All New ball joints It has all, new seals, bearings and gears in both axles
The front has a Ruff Stuff Specialties diff cover. It has adjustable radius arms, with heims on the frame end.
The front has a WJ knuckle swap, with larger dual piston calipers and crossover steering.
Over The Knuckle steering Front brake calipers, pads, rotors, and extended brake hoses are almost new.
New tie rod, drag link JKS MFG, New adjustable double shear track bar with johnny joint JKS MFG.
It has a durango steering box which makes it easy to turn the 35's.
New rough country sway bar quick disconnects.
Brand new Iron Rock steering stabilizer
Front and mid Frame stiffeners by HD Offroad Engineering, custom high clearance rock rails.
The rear end is a 31 spline Limited Slip 8.8 rear with Disc brakes.
Steel braided brake line in rear, Ballistic Fab diff cover in rear
Ruff Stuff Specialties 8" spring perches,
HD Offroad Engineering Shackle relocation Brackets. The rear flexes great!
New Slip Yoke Eliminator on it. New Rockcrawler 15x8 with 3.75" backspacing with matching spare, Gas tank skid,
Custom made transmission and transfer case skid plate.
Custom rear bumper with swing out tire carrier was made with 1/4" steel. it has 2x4 boxed tubing wich goes up in the frame and mounts like a hitch for added strength. the bumper
is very stout!! The Front bumper was also made with 1/4' steel. It has a 9,000 pound winch that has never been used.
The light bar on top consists of 4 100 Watt lights that are VERY BRIGHT!!! They have been wired in safely with relays as well, no fires here. Brand new KC Appolo lights on grill
guard.
Brand new THule roof rack with Thule MOAB basket and extension.
Under the hood it has a cold air cowl snorkel.
Brand new Duralast/Gold battery with 8 year warranty. Has been relocated to the drivers side to make room for a York On board Air setup.
The body has over 250,000 miles on it but the engine, transmission, and transfer case have around 150,000 and they all run great! Transmission had a complete service done 500
miles ago.
The radiator was replaced a year ago and was flushed about a month ago.
Brand new FLowmaster Super 44 installed. Nice deep growl to the exhaust and a little more pickup!
It has Grand cherokee Seats front and rear which are 100 times more comfortable. no rips or tears anywhere. the rear has a 60/40 split seat...
Interior is in great shape! Brand New Rugged Ridge A/T floor liners in front.
The windows have 20% window tint all the way around.
Premium Sound! New Kenwood ipod ready radio with remote, JL Audio speakers in door and rear and 15" sub in the rear. Sound is amazing.
I may have missed something, but all parts listed above with the exception of the bumpers and rockrails have less than 5,000 miles on them!
This jeep is ready to go! and should not need anything for a while.
I drive it back and forth to Cookeville every day and it does 80 MPH smoothly! There is no death wobble or scary stuff like that. This jeep was built right to be safe on the
road and very functional off road. No shortcuts in the build, only high quality.
Heat and A/C all work great! Brand new heater core, New NSS switch, new starter, new plugs and plug wires and probably more stuff that I can't remember right now.
Here's a link to the build process
http://www.jeepforum.com/forum/f11/klint96xj-build-thread-1174280/
Email me with questions or if you need specific pics
guard.
miles ago.
