hey wayne i read thought some other forums about the code that was given, a couple of the forums said to disconect the battery to reset the computer and get everything synchronized and another said to remove the ckp or the cmp and re-install, in you case the crankshaft sensor. so i hope that this helps a little, but i would try to un-install and re-install the crankshaft sensor sense it sounds like it was installed improperly.
