primegreen
- California
You don't need a DPA at 4.5".
I do suggest a steering upgrade. I know where you can get both the lift and a steering upgrade....![]()
:spin1: where!? :spin1:
All depends if a person has the equipment to do the necessary fab work.I wouldnt say "digging ditches", yeah its bigger and I agree maybe not the most ideal. If I was scrapping the 30 I'd go 8.8 over a 8.25 or 44 just my 2 cents though.
No, it's got the 27spline axles!
If your regearing you could swap out the shafts, I've got a set after I changed to Yukon's!
To change the shafts from 27 to 29 spline, you'd also need to get a 29 spline carrier.
i assume you meant XJ, not ZJ?Which are easily had from any 97 up ZJ with an 8.25 in a hour at your local pick n pull.
A disc brake swap can be pickex up at the same time.
You should be able to put in a Aussie locker for a 29 spline 8.25 then just use 29 spline axles
Would a 96 Cherokee 8.25 not be a good upgrade over the D35
Nope i meant ZJ. I dont know about your area but in mine finding a 97 up xj in a wrecking yard is a pretty rare thing. Tons of ZJ's but not XJ's. If he has the housing pulling the carrier and shafts out of a zj is a viable option and am easy upgrade for the 27 spline.i assume you meant XJ, not ZJ?
"im going to take all the internals from this housing, and put it in that housing because i got it for free." at that point, why even bother with the free housing? just buy the complete one at the JY and tear it apart for a rebuild in the comfort of your own garage, screw carrying it out of the JY in pieces.
You're correctZJs only came with dana 35's or dana 44A's unless I'm mistaken
You're correct
