1991 XJ Chrysler 8.25 axle with explorer disk brakes
(•:XJ:•)
arkansas
The axle does not have a ring and pinion nor does it have a carrier. It does have the yoke, new brake pads and turned rotors. The Ford disk brakes are attached to the axle by a custom bracket that I had machined and then welded to the axle. Very sturdy set up, the bracket has a lip that the caliper bracket rides on. I am asking $150.00 for the axle. If you are interested then I can send you pictures.
[email protected]
Thanks, Jereme
