So, this is where my work begins. The live axle is under the vehicle, the new upper control arms are already installed, but that is it. I had no idea how to adjust the control arms to the correct location. I found some info online on a similar kit. I took off one of the upper arms to see what it was set at, and it jived with the info I had found. So, I adjusted the lowers accordingly in hopes it was right.
I installed the springs, shocks, calipers, brake rotors, brake pads, brake lines hoping it all made sense as I went along. The gentleman that was supposed to do the work does this type of work all the time. I do have a lot of automotive knowledge, but this was a jumble of mix match parts that I had to hope worked. So far so good...
