Don Becker
- Beaverton, Oregon
Hi, all! I've been off of here for awhile but I still have my '88 and the wife's 91 XJ's.
I have actually spent quite a bit of time searching on here, in the archives, for the answer to my specific problem, without success.
I do not currently have a cooling system problem - - well, at least not overheating. This is (as noted in the subject line) re the '88 and the cooling system is fully retained as original, closed system.
The electric fan comes on and operates just as it should when the a/c or the defroster is in operation.
Always before, (with a/c or defroster off) that electric fan would cycle on and off as the temperature got to the 190 degree range - - especially at idle. Now, it doesn't come on at all.
See diagram (I hope it will attach here):
[/IMG]
I have been through all of the checklist but, at item 7, I do not have battery voltage at terminal 2.
I think that is controlled by another fusible link but, I don't know for sure and if it is, I don't know where that fusible link is.
Or, if that voltage is actually supplied when the switch in the radiator is on, I might have a problem with the sensor/switch in the radiator - - I know that switch is in its ordinary open position - - - what I'm unsure of and will maybe need to test further is whether that sensor/switch is actually closing when the temperature rises.
Thanks for your assistance with this.
Don
Don
