1987 NP231 Transfer case drain plug size
62tmar
MN
I searched using NP231, and got close. I bought a 30mm socket for the fill plug, but the drain plug is the problem.
It has an 8pt torx (sort of) slot in the center of the plug. A socket will not fit, because the bolt plug is too close to a bulge in the case.
I would like to know what size that 8pt (sort of torx) is. I have a picture, but I am not allowed to post attachments.
Thank you,
62tmar
Fill plug and drain plug are the same - you might be messing with the wrong bolt/plug! careful!
Is this what your transfer case looks like or is it different? http://www.fototime.com/03C570A95ED2771/standard.jpg
Try posting the image on imageshack or photobucket and posting a URL here - should work.
You might have a NP207.
Try an open-end 1 3/16 wrench.
1987 could have either 207 or 231 part-time 4x4, and that doesn't look like my 231.
Can you fit a 3/8" drive into that plug?
That is one nice looking 87, and it is in MN?!?!?
joe_peters,
Thank you very much, saved me from buying another tool. The 3/8 worked very well.
Back to the "Old-Folks Home" for me.
62tmar
