moparcyco
- Preston Idaho
To all who have done this did you have to use the stock alt charge wire? The one that hooks to the alt stud. It looks like it goes back up through the harness under the pdc somewhere. Or do you just bypass it? Its a 93 with 4.0 and the small two stud pdc.
I was going to go straight from the alt stud to a 150 amg fuse then to the battery. Then run a wire to the starter and pdc from the battery. Am I missing anything? Or do u have to upgrade the old feed wire as well? where does it go? Thanks guys
