1310 Yoke U-Bolts
95XJ_Cbiscuit70
South Jersey
Can anyone with the advanced adapters SYE kit confirm that Spicer 2-94-28X u-bolts will work with the yoke? I ordered a tom wood's CV driveshaft and just realized the AA SYE kit din't come with the u-bolts. I want to pick up the bolts before the shaft arrives.
Thanks
No u bolt shoud be needed to connect a DS to the output yoke on a tcase. Bolts go through the output yoke and thread into DS. Tomwoods should send you mounting bolts with your new DS. The u bolts your reffering to are for the input yoke on the axle side u joint, not the SYE.
