JeepFreak21
- Cameron Park, CA
Thomas 4101-DC
The Thomas is the only 12 volt compressor I found that can compress one cubic foot per minute at 100 psi and is rated for continuous duty. This is the compressor that the Turtle Expadition guys use and the same one that is used on the Hummer's Central Tire Inflation System. Basically... it's about THE BADDEST 12V compressor out there!
Specs:
High Pressure Air Compressor/Vacuum Pump
Power Rating 1/3 HP
Voltage @ 60 hz 12 VDC
Full Load Current 28.0 Amps
Maximum Pressure Continuous/Intermittent 100/100 PSI
Free Air Flow @ 10 Inches Vacuum 1.40 CFM
Free Air Flow @ 100 PSI 0.95 CFM
Free Air Flow @ 20 PSI 1.75 CFM
Free Air Flow @ 20 Inches Vacuum 0.60 CFM
Free Air Flow @ 50 PSI 1.34 CFM
Links:
http://www.thomaspumps.com/products/oem/pdf/Taskair1_4.pdf
http://www.4crawler.com/4x4/CheapTricks/OnBoardAir.shtml
http://www.earthroamer.com/main_truck/truck_air.html
http://www.grainger.com/Grainger/productdetail.jsp?ItemId=1611784051
This is new in box and never been used!! This compressor sells for upwards of $600 (see grainger link above).
I'm asking $460 OBO - And I will consider any trades.
Thanks,
Billy
Specs:
Power Rating 1/3 HP
Links:
Thanks,
Billy
