rock rash NAXJA Forum User Location Anywhere USA Jan 20, 2005 #1 would a 1" tcase drop work with stock crossmember...?
J jeepguy97 NAXJA Forum User Location clearfield, pa Jan 20, 2005 #2 Yes. You can make your own drop if you want with some washers or spacers on the exisitng crossmember bolts. But yes you can use the existing crossmember.
Gil BullyKatz NAXJA Forum User Location 2003UB313 Planet ERIS Jan 20, 2005 #3 Sure as long as the bolts are an extra 1" long
W Wondo NAXJA Forum User Location Elysburg, PA Jan 20, 2005 #4 yes it will work....use spacers, or a whole lot of washers
G Gojeep NAXJA Forum User Location Australia Jan 20, 2005 #5 See the write up I have to get the details you need to make your own as these guys have said. www.go.jeep-xj.info
