04 GC overland hard to put gas in
Cerpindicular
Springfield, Mo
Since i have gotten this jeep it has had an issue filling the tank and wanting to shut the pump off after a few seconds unless i pump it at a trickle which takes forever. Oddly enough if the weather is just right it seems its not as big of and ordeal but that is very rarely the case. i did pull the rear bumper cover and disconnected the hoses that I thought were for venting and blew air throug them. Fuel fill hose does not appear kinked. Any suggestions? The plastic check valve seemed ok
I had the same issue on my XJ. somehow the plastic anti-syphon ball spring had moved positions, it should be inside the ball, somehow it had moved to outside the ball. I would bet you money that your issue is that anti-syphon ball valve. Pull the tank, and the pump and reach in there and pull the spring out.
I replaced all my hoses, my evap valves, and my fuel pump before I decided to yank the anti-siphon spring out.
Sent from my SAMSUNG-SM-G891A using Tapatalk
