1988JeepXj
- Redford, Mi
Coolant temperature dropping out while driving, but not fully. Drops from operating temp to around 110-120 degrees, and back to operating temp seemingly at random, for random lengths of time. Not the gauge, engine idle changes with temp sweep. I doubt it's a mechanical problem like a thermostat, the heat doesn't change, and my trans temp gauge remains steady. It sweeps fairly quickly, it seems like a loose or corroded connection, but I couldn't replicate it in the driveway by wiggling connectors and harnesses. No codes.
Anyone ever have this happen before? ECT going bad? Cruddy ECT connector? It looks okay, I'm probably going to deoxit and grease the connector and see if that helps. Usually they just fail open or closed, but I've never had one go bad on a XJ.
Weeding through all the threads and forums about XJs with actual cooling system problems makes researching this very difficult. :looney:
