CMNCHE
- Pennsylvania
Im sorta baffled. Im used to working on Mopars and I can't seem to find the cause of this. My GF has an 01 Monte Carlo SS with a 3.8 V6. It runs fine at idle and up to about 50 mph, but above that or if you try to punch it below that it just falls on its face. I have a GM scan tool and its showing me missfires on mostly all the cyls when this happens. I know the problem is a multiple cyl missfire, but I cant pinpoint the cause. I have replaced the plugs and wires, fuel pump and filter, and cleaned the fuel rail and injectors. Is it possible the crank sensor could cause the timimg to be out under load? I am just about out of ideas?
