Old July 5th, 2018, 11:14
RCP Phx RCP Phx is offline
8.25" axle shaft ???
Does anybody have the measurement (or can measure one) for the diameter of the "major " area of the c-clips? Not the c-clip pin diameter.
Old July 5th, 2018, 13:38
SByota SByota is offline
Re: 8.25" axle shaft ???
The smooth end of the axle past the C-clip groove? My 97 29 spline 8.25” is 1.097”.
Old July 5th, 2018, 16:19
THX !
Old July 5th, 2018, 19:15
I found both 1.0" and 1.125" ID shims in .010"/.012" so I will order some of each. I might have to address the OD as they are both 1-5/8" and the spare c-clips I have measure 1.580".
Old July 5th, 2018, 19:19
Overland's Avatar
Overland Overland is offline
I love that my town has a good gasket shop, if you can draw it, they can make a shim out of it in any thickness or material you want. They even sell scraps, so I can make my own shims from stock in the toolbox if I'm away from town.
Old July 5th, 2018, 20:46
What are the shims for?
Old July 5th, 2018, 21:21
For reducing the end play on my axles. Since my disc conversion (KJ), I want to reduce my pedal travel.
Old July 5th, 2018, 21:42
I see. I’m using ZJ parts to do mine, I should probably do the same. What about just making thicker c-clips?
Old July 5th, 2018, 22:26
You could try, but they're really hard and I don't know how that would come into play with my locker fitment.
Old July 6th, 2018, 10:06
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I'm surprised you have pedal travel from that, I'd expect the caliper slide pins to handle that. Maybe they need greasing or the bracket arms that the brake pads ride on are notched and the pads are binding so they can't slide?
I'm spoiled... I can have shims and brackets cut to my spec by the applications engineers at my work anytime I want if I buy the material. Working at a laser cutter manufacturer has its benefits
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old July 6th, 2018, 13:50
The pads and calipers are brand new. Whether you have "floating calipers" or "floating piston calipers" any kind of end-play eats brake travel. I'm spoiled because of being used to "race" brakes!
Old July 6th, 2018, 14:17
JohnX's Avatar
JohnX JohnX is offline
Sarge
So I'm curious now, how much end play did you measure at the disc?
I don't want to play anymore
Old July 6th, 2018, 16:11
I have .015" on the Drivers side and .0135" on the passenger side.
Old July 6th, 2018, 17:48
JohnX's Avatar
Sarge
Seems like a lot of work for so little room for gain.
I'll be driving mine.
Old July 7th, 2018, 04:36
Well I just dropped 300$ on EBC pads so I don't mind spending a couple bucks on shims and a hour of my time to make them work like "I" want!
9" axle shaft bearing 90xj_zach Modified Tech Discussion 1 December 20th, 2012 19:18
30" tires, d60 axle shaft and a trail ready cherokee OHIO OffRoadOhio MWC For Sale/Wanted Forum 0 June 10th, 2009 16:25
"Clicking?" from axle shaft between rear end and brakes when braking greenlawnjeeper OEM Tech Discussion 13 July 19th, 2004 10:20
Longfeild "U" Joint- 1... Warn Axle Shaft- 0 FarmerMatt Modified Tech Discussion 36 March 3rd, 2004 12:46
