ParadiseXJ
- Paradise, CA 95969
After replacing just about everything in the front of the MJ's engine (alt, water pump, P/S pump, idler pulley, fan clutch and belt) I still have an intermittent ...well...like the title says, a Mournful Wail.
Finally I looked at the harmonic balancer and the rubber piece looks like a wavy piece of spaghetti, so I gotta replace that this weekend.
My Q: How hard is it to replace the HB, front seal and gasket with the radiator et al. still in place. I have yet to find a single nut on this thing that won't turn on the first try with a little PB.
Is it worth pulling the rad and everything or is it easy enough to work around it??
