NorCalChris
- Central Coast, Ca
Ok. heres a quick write up on how to do a rear main seal. If I missed anything feel free to add to it. I'ts late at night and some people have been asking me about when I did mine. So here it is
This is for the 4.0
Remove steering and track bar(I had to because I didnt use any jacks or anything. but im also sitting at 6inchs of lift)
Drain oil.
Remove oil pan.
Remove #7 main cap
Loosen caps 6,5,and 4
Remove lower portion of seal out of #7 main cap.
Use brass punch and your choice of hitting device. I debated on a baby seal club or a rubber mallet.
After hours of debating I used the rubber mallet. lol
Hit seal on left side, switch to right side. It will break loose faster if you switch back and forward left to right.
Theres a wire inside of the seal. Its a little dot on each end. That is the preferable place to hit.
Once upper seal is removed.
Coat the new piece with lots of assembly lube and i mean lots!!!
The easier the better right.
I choose to even squirt a bunch up around the crank.(all the extra is going to be pushed out and you just wipe it off)
Also make sure you place seal in correctly, with the lip facing the front of the motor.
Now coat lower seal with rtv and slide into place with lip facing correct way.
Install main cap.
Torque specs are 85 ft/lbs for the caps. So tighten to 40 ft/lbs and smack rubber mallet til cap seats. continue this on the rest of the loose caps. making sure you tighten the caps from the inside out(ie. cap #4,5,3,6,2,7,1) then go back and re torque to 85 using the same technique.
Scrap off all old gaskets. Apply silicone (or gasket) to oil pan.Tighten oil pan, install steering and track bar.
This is for the 4.0
Drain oil.
Remove oil pan.
Remove #7 main cap
Install main cap.
