Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 35 votes, 4.89 average. Display Modes
Old October 30th, 2010, 21:30
old_man's Avatar
old_man old_man is offline
What are you doing to your rig - the continuing saga
It would be interesting to know what people are doing on their rigs. You might find someone to help or maybe someone with parts you need.
I'll start it off.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old October 30th, 2010, 21:32
old_man's Avatar
Re: What are you doing to your rig - the continuing saga
Currently I am working of finishing off my remote reservoir for my power steering pump for my hydroassist.
I am also working on a suck down winch.
Old October 30th, 2010, 22:01
Frank Z Frank Z is offline
I need to replace the rear hatch, swap the dented doors for a set that I got from Troy a couple years ago, bang out some dents....and then repaint it.
Old October 30th, 2010, 22:03
old_man's Avatar
Frank, I have a pin welder for pulling sheetmetal if you want to borrow it. I also have a full line of DAs and inline sanders as well. Compressed air rules when doing body work.
Old October 30th, 2010, 22:05
madmike283 madmike283 is offline
Control arms are being delivered this week. Was going to post up and see who's got time/room to help me do a upper/lower/drop bracket install next weekend.
Also, kicking around the idea of selling a few items to free up some $ for regear/locker install. May even end up with enough $ to buy a set of BOR leafs and shackles.
Then some armor...
and then...
Old October 30th, 2010, 22:07
With the exception of 1 nasty dent on the passenger side rear quarter, the dents are all small enough that I can use my shiny new HF hammer and dolly set.
Everybody sing...
Bang Bang Maxwell's silver hammer came down on her head.
Bang Bang Maxwell's silver hammer made sure she was dead....
Old October 30th, 2010, 22:32
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
At some point in the near future (I need to order some parts first) I need to replace the cat and muffler. Whoo-hoo..the joys of owning a stocker!
Jim www.yuccaman.com/jeep
Old October 30th, 2010, 23:53
fireLt. fireLt. is offline
Well my list for Jeep #1 is
Fix the front locker
Fix the tie rod bent at French Creek while trying to get through it in the rain. Old Man remembers that winch fest.
Install the bling power steering pump and remote res that's been sitting in the shop since Spring.
A general going over/service.
Jeep#2
A total detail inside and out
Budget boost with some nice wheels and 31's
Old October 30th, 2010, 23:59
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
Now that the BOR rig runs........
-Install RE track bar bracket brace
-Install Durango steering box and hydro assist
-Figure out if I have a bent wheel or out of round tire up front
-Finish the re-install of the stereo components after the cage install
-Replace and seal up the oil filter adapter
-Replace the fuel gauge sending unit, probably a new pump since I'll be in there
-Weld on the nifty new sway bar mounts that I got from a Pirate4x4 guy to the axle
-Figure out where to mount the CO2 tank
-Fab up a rubber bushing support mount on the hatch to help keep the rear tire carrier from wiggling
-Fab up legs to the bases of the roll cage to tie into the unibody stiffners
-Finally replace that dented front fender
-Make a decision about if the new Bushwhackers are gonna go on or not..... and then what I'll do for flares if not......
And then........ and then......
Old October 31st, 2010, 00:13
austinaubinoe's Avatar
austinaubinoe austinaubinoe is offline
Im working on getting money for an AJ's rear tire carrier, Super Squares, and a T&T crossmember/ t case skid..............AND some H1 double beadlocks/ 37" military Goodyear radials.
I had the money set, but then I went ahead and got me a '91 Grand wagoneer! God the addiction never ends
Old October 31st, 2010, 02:49
mcantar18c mcantar18c is offline
See, I ain't the only one!
-Paint plastic trim
-Deal with headlight lenses
-Build and install axles
-Find and install lift
-Find and install wheels/tires
-Install sound system
-Build and install armor
Old October 31st, 2010, 06:03
eflores eflores is offline
now that ive recouped all the parts that went into "dino's" front axle ill be installing my axles and gears/lockers in mine. total revamp on hers....exhaust front to back, suspension, tires etc
combining this
and this
Old October 31st, 2010, 14:11
collkid's Avatar
collkid collkid is offline
Switching all, well most, fluids to Full Synthetic before winter.
Install interior "Mood Lighting" LED's.
Old October 31st, 2010, 15:09
xjcase xjcase is offline
Putting flat screens underneath so the rocks can watch tv
Adding a fold out, full size snooker table to the hatch
Adding LED spinners a la http://www.youtube.com/watch?v=cL9PU08Xuwo (skip to 55 seconds)
cause I've been playing this game non-stop lately
But really, replacing front pinion seal and putting a PS cooler somewhere safe.
Kind of sketched about the pinion seal replacement, but I assume I'll be relatively safe counting the rotations and then going a little past when re-tightening. (anyone have any words from experience on this?)
Old October 31st, 2010, 16:07
Front or rear axle?
Rate This Thread:
Death wobble, the continuing saga RockTracXJ Modified Tech Discussion 11 June 2nd, 2010 05:46
Continuing the downward spiral of 4x4 design Lawn Cher' Non-Tech / Off Topic 28 April 19th, 2010 11:49
The saga continues... sams88 User Support, Questions and Suggestions 0 September 1st, 2007 22:08
1990 AC saga keeps going... cherokee4fun OEM Tech Discussion 14 June 13th, 2007 21:02
'00 Headers, and the continuing lack of them KCNMDE Modified Tech Discussion 0 August 8th, 2004 14:21
