Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep CJs and Wranglers > Wrangler YJ, TJ, and LJ (1987 - 2006)
Wrangler YJ, TJ, and LJ (1987 - 2006) Technical forum for the Wrangler YJ, TJ, and LJ Unlimited.
Old October 17th, 2018, 08:21
mattdragg mattdragg is offline
engine swap
will at 4.0 in a 98 wrangler fit in a 92 jeep wrangler with a 4.0
Old October 17th, 2018, 08:27
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: engine swap
Yes, but make sure you use the sensors from the 92 motor.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old October 22nd, 2018, 01:05
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Re: engine swap
It may use different mounts on the motor for the motor mounts. I'm not familiar with how the 92 4.0 is bolted in.
mac 'I'm not sure if the exhaust is the same either' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old November 26th, 2018, 17:23
tm8chris tm8chris is offline
Re: engine swap
Here are some good info if you're planning to put a 4.0 into your YJ. -- https://www.jeepforum.com/forum/f12/...mation-537763/
Rate This Thread:
Engine swap, lifting engine? jhc7399 OEM Tech Discussion 20 February 2nd, 2015 14:51
Feeler: 1996 VW TDI engine for engine swap alex22 NAC Classifieds 0 September 24th, 2012 20:52
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
engine swap: 96 4.0 auto engine where 92 4.0 manual tranny engine is cjben OEM Tech Discussion 4 January 21st, 2010 18:52
Engine Swap mikes offroad OEM Tech Discussion 4 May 20th, 2007 10:32
