Old May 24th, 2007, 06:36
damo252's Avatar
damo252 damo252 is offline
Double a 242?
I want to go with a dual transfer case option for the ability to choose different gears for all situations.
The other situation I have is I don't have a lot of money to go out and by a atlas 2 or stack or anything like that.
I have heard about the 231/dana300 double kits, can this work with a 242?
Who sells the kits for either the 231, or possibly the 242?
Old May 24th, 2007, 06:43
supsa's Avatar
supsa supsa is offline
Re: Double a 242?
I haven't seen anything for the 242 but the 231 there is alot out there. RE sells a kit
Old May 24th, 2007, 06:58
Dundy's Avatar
Dundy Dundy is offline
Re: Double a 242?
You could probly get it to fit but you also need to think of driveshafts because you'll need 2 new ones. That'll take a pretty penny out of your pocket...
Old May 24th, 2007, 10:49
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Double a 242?
The driveshafts will be nothing after a $400 kit and a $200 dana 300, plus a couple hundred more in misc parts, shifters, boots, welding, etc.
Its a big undertaking. Not undoable, but you'll be halfway to an atlas when its done.
Old May 24th, 2007, 11:22
Gaius's Avatar
Gaius Gaius is offline
Re: Double a 242?
As far as I know, Duffy hasn't made the Box4Rocks for the 242.
Here is the info for the 231:
http://www.pirate4x4.com/forum/showt...451754&page=14
Old May 24th, 2007, 12:01
ZachMan's Avatar
ZachMan ZachMan is offline
Gone but not forgotten...
Re: Double a 242?
no 242/231 is pretty weak to use as the second box. Most do 231/300.
Stem cell transplan 11/8/07
You tell him to put that thing in 4-low, take off his My Little Pony panties and drive it outta there
Old May 24th, 2007, 13:15
Gaius's Avatar
Re: Double a 242?
I should add, you can do a 231/242 box as the 231 as the doubler, but not a 242/D300 setup.
Old May 24th, 2007, 19:31
damo252's Avatar
Re: Double a 242?
Why is the 300 so much better than the 231/242? option
Old May 24th, 2007, 19:33
damo252's Avatar
Re: Double a 242?
Originally Posted by Gaius
I should add, you can do a 231/242 box as the 231 as the doubler, .
This is what I want to do. I don't see it done. I went through a hundred threads on pirate it seems, and this is very rare, why?
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Re: Double a 242?
dana 300=twin sticks, geared drive, cast iron case........
Old May 24th, 2007, 19:34
damo252's Avatar
Re: Double a 242?
I am thinking out loud here, but can't the tera low kit and the tera 2 low hit be put into a 242 making it have similar gear options as the 300, cast iron case to me only means weight, I can protect the t-case and I only run a 4.0 in the cherokee, I shouldn't break any chains. is the only issue the twin sticks?
Old May 24th, 2007, 19:39
BRIANHO13's Avatar
<- Yum Chocolate
Re: Double a 242?
the 2 low option only gives you rear wheel only. twin sticks gives you front, rear or both. 4:1 is nothing like 7.2:1..........
Old May 24th, 2007, 19:47
damo252's Avatar
Re: Double a 242?
I have never had the front wheel drive stuff is that really that nice of an option to have?
Old May 24th, 2007, 19:49
BRIANHO13's Avatar
<- Yum Chocolate
Re: Double a 242?
look up the term "front dig"
Old May 24th, 2007, 20:00
Big Hank's Avatar
Big Hank Big Hank is offline
NAXJA member #435
Re: Double a 242?
Theres a demo at the end of this video. enjoy
http://youtube.com/watch?v=CPzunPN_Ljs
Life of the Chili Pepper XJ ==>Click Here
Double your gas milage RichP Non-Tech / Off Topic 9 April 19th, 2007 12:35
ok just double checking generalleexj Modified Tech Discussion 7 September 3rd, 2006 10:19
Double electric fan herreraxto Modified Tech Discussion 5 July 4th, 2004 03:23
double cardon instead of sye? MCD Modified Tech Discussion 8 May 4th, 2004 09:47
