Old June 2nd, 2003, 18:10
XJguy XJguy is offline
On a Time Out
My new diff cover
Had to change the fluid, so I gathered some pieces of scrap steel I had lying around and made me an extremely stout and rather good looking front diff cover if I do say so myself. The front is 2 layers of 3/16" plate, the edges are single layer, the top round portion is 1/4". All welded up solid and ground smooth. I also braced the back of the side where the filler hole is.
XJguy
Old June 2nd, 2003, 18:15
ChilliPepper ChilliPepper is offline
Looks beefy!
Old June 2nd, 2003, 18:58
Slip Kid Slip Kid is offline
That'll buff right out
That's sweet, I will be very impressed if you break that.
I painted my cover red, does that count?
Old June 2nd, 2003, 20:20
Matt's Avatar
Matt Matt is offline
Cap off those hollows or you will be filled up with muck or rocks depending on where you wheel - nice job on the lower bolts - mine doesn't stick out quite as much but has seen plenty of use (and I can still access the bottom bolts use an appropriate tool - besides an easy-out)
Matt
Old June 2nd, 2003, 21:21
Royce Royce is offline
What did you coat those axles with Matt?
Old June 2nd, 2003, 21:25
On a Time Out
Thats a sweet job Matt!
I left the bolts holes hollowed out so that the mud and water that collects inside can drain out. I shaped mine that way so that it acts like a skid plate that will deflect rocks and help it slide over obstructions. Originally I was going to do it like yours, but got lazy to do all the banging necessary to contour it that accuarately as you did.
XJguy
Old June 3rd, 2003, 10:16
Matt's Avatar
Royce -
It is rustoleum hammered finish (color is Dark Bronze) but lays down kinda silvery - good for covering not so perfect surfaces...
I got it from lowes....
XJ-guy: thanks - that should work for most stuff; if it gets all plugged up you can always just roll it A good inversion would shake all that stuff out and test your cages while your at it (two for one!)
Matt
PS - I am so anal I made about 15 trianglar slices that make up that cover - all welded and ground - then welded and more grinding, with more grinding, then some flap wheel action, ect...
diff cover plug leaking chad OEM Tech Discussion 2 November 21st, 2003 11:17
remove diff cover? mn_xj OEM Tech Discussion 6 August 29th, 2003 07:56
random diff cover reinforcement mod Beezil Modified Tech Discussion 19 August 2nd, 2003 06:46
What to torque bolts to on 8.25 diff cover? Locrdup OEM Tech Discussion 3 July 21st, 2003 19:45
Diff cover revisted ZPD Modified Tech Discussion 3 June 20th, 2003 21:21
