Old October 1st, 2010, 17:09
NCjeepgirl83's Avatar
NCjeepgirl83 NCjeepgirl83 is offline
How can I mount a 31" tire on the factory spare tire mount?
Hey all,
I know I read (either on here or over at the Jeep Forum) a write-up of how to mount an oversized spare tire to the factory spare tire mount in the trunk. I want to do just that, but I've searched exhaustively and can't seem to find the thread with pics...
Thanks!
Old October 1st, 2010, 17:56
VAhasnoWAVES VAhasnoWAVES is offline
Re: How can I mount a 31" tire on the factory spare tire mount?
remove the bracket at the bottom. its 4 bolts.
depending on the bolt you have that holds the spare (ive seen some with more offset than others) you may be able to reuse the half sphere retainer thing. i didnt, i just put the bolt through the rim as if it were a lug. screwed down the wing nut thing.
it looks like it hangs out and would hit the rear hatch, but it doesnt. the hatch closes just fine. some say you need to massage the fender well with a BFH, i didnt. anything bigger and your going to have to move the mounting brackets that hold the seat back forward.
Old October 1st, 2010, 19:21
casm's Avatar
casm casm is offline
I'd be interested to hear if this works on her '99 - it doesn't on my 2000. Unlatching one or both sides of the rear seats made no difference, FWIW.
I never had an issue with the fender well or roof clearance either - it just won't stand upright and still let the hatch close.
Old October 1st, 2010, 19:41
mine sits crooked but doesnt move. clearance isnt a problem with the hatch, but i have to squeeze it under the speaker bar. i can take a few pictures if you would like.
my seat is latched on both sides.
Old October 1st, 2010, 20:11
Darky's Avatar
Darky Darky is offline
What year is yours though? My 96 fit a 30 no problem in the stock spot. My 33 now, of course is laying down on the floor.
Old October 1st, 2010, 20:24
4.3LXJ 4.3LXJ is offline
I couldn't get a 31" swamper to do it. I had to build another rack.
Old October 1st, 2010, 20:54
crappy pics cause its dark and on my phone... but you get the idea... you can also note that my spare is VERY worn down. itll depend on the actual dimensions of your "31" as they are not all the same.
held down:
tight squeeze:
and here you can see just how much it hangs out. if you can squeeze it in behind the tail light and have it sit on the fender well, the hatch should close on the late models:
Old October 1st, 2010, 20:57
casm's Avatar
Dammit, I could swear I've done exactly the same thing but it Just Doesn't Fit. The soundbar is no issue for me either - but like I said, it would just never clear the hatch.
Back to the roof carrier, I guess.
Old October 1st, 2010, 21:02
or this:
http://www.go.jeep-xj.info/HowtoSpareWheel32inch.htm
Old October 1st, 2010, 21:20
casm's Avatar
I hear you - it's just that that does both the things that everyone says isn't necessary in this case :/
Not a big deal either way; I'm used to it living on the cargo area floor at this point. I'd just like to know if it works on her '99 so that I can start trying to figure out what needs to happen on a 2000.
Old October 1st, 2010, 22:07
RCP Phx RCP Phx is offline
Let the air out,and it will fit fine.
Old October 1st, 2010, 22:37
Thanks sooo much guys for all your help! Just to clarify, it's a 31" BFG Rugged Trail (the closest thing the dealer could get to my 31" BFG A/Ts)...I'll take measurements tomorrow to get the exact dimensions...
Old October 1st, 2010, 23:16
take measurements? just use their website.... is the tire new? thats probably the problem.
overall diameter on the BFG rugged trail = 30.7":
http://www.bfgoodrichtires.com/tire-...ail-t-a-tires?
overall diameter of my Claw = 30.5":
http://www.mickeythompsontires.com/t...BajaClawRadial
now consider the fact that my almost 3/4" deep tread is close to bald on my spares... your going to have to drop the PSI and squeeze it in or move the seat brackets. i vote move the brackets.
Spare tire mount....... misterjeeper Modified Tech Discussion 3 September 13th, 2006 17:11
Surco 40x50 rack with spare tire mount and hi-lift mount mikeswrangler NAC Classifieds 5 May 20th, 2006 16:42
anyone mount spare gas tank to factory tire carrier dandecicco Modified Tech Discussion 4 November 23rd, 2004 14:37
Spare tire Mount AJ-MJ Modified Tech Discussion 3 October 5th, 2004 19:01
