Old November 3rd, 2019, 17:18
jmg222 jmg222 is offline
rear view camera mount to go over large spare tire -- fabbed and installed
Got tired of not being able to see out of my review mirror (thanks to the 35" m/t on the rear tire carrier) had rare couple of hours free this weekend , so welded up a quick-and-dirty mount for a review camera to sit on top of the tire, wired into my double-din video in -- works great! (thinking of adding in a third brake light on it):
Daily drive: 2018 Jeep Grand Cherokee TrackHawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: '19 ZZ6 350 sbc, 405HP/405 lb-ft; holly performer EPS, Terminator EFI, headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old November 3rd, 2019, 17:34
techno1154's Avatar
techno1154 techno1154 is offline
Re: rear view camera mount to go over large spare tire -- fabbed and installed
The video graphics look good. I like.
How do you get a double din in the XJ?
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 3rd, 2019, 17:50
Was not a pretty project.. involved cutting into the hvac ducts behind the existing radio, moving the hvac controls down and getting rid of the center vent, blocking that off, modding a standard bezel, and then I switched from horizontal mechanical hvac controls to dial mechanical hvac controls, since they were a bit shallower (which required a set of relays to convert from neg to pos edge trigger, reworking vaccuum lines, etc). I don't recommend it.
If you have a 92 or newer (or whenever they went with the new interior) , it's supposedly far, far easier, basically just modding the plastic bezel.
Old November 3rd, 2019, 18:11
heres a better pic of the double din in case you're interested:
Old November 4th, 2019, 09:03
techno1154's Avatar
OK. I see wat you did there. Nice project. When I get my DD back on the road I may try that.
My XJ is a 1996. It should not be too difficult.
Patrick
#594
Old November 5th, 2019, 12:54
I believe the '96 has the same interior I have.
If that's true, I don't recommend doing it... it's far, far more trouble that it's worth, requires hacking into hvac, and pulling cutting all sorts of crap inside the dash. It was miserable work. when I did it the single din head units with the pull out screens were horrible -- now, the screens are actually just as good as the Double dins. If I were going to do it all over again, I'd keep the dash stock and go with one of those.
Old November 6th, 2019, 10:16
techno1154's Avatar
In the past, I looked at some of those flip up screens and decided against them. I will take a look again.
Patrick
#594
Old November 4th, 2019, 13:58
thetastelingers thetastelingers is offline
Sony makes a single din unit that you don't have to do so much cutting.
Here it is molded into my 01
Pay no attention to the mismatched color. I gotta fix that soon.
Old November 4th, 2019, 18:48
I know, I didn't want one of those pull-out screens though.
you're version interior is super easy to do, I did that for one of my friends, took less than a quarter of the time as my '88. looks good too
Old November 4th, 2019, 22:59
bajabronco bajabronco is offline
Like you I couldn't see crap behind me with my 37's so I installed a rear view camera as well. My camera was one of the license plate ones - I just cut the license plate mount strip part shorter, drilled two holes , and then mounted mine directly to the spare tire with two bolts. My camera is in my rear view mirror.
Camera mounted to rear tire - I simply have to remove the two bolts if I need to ever use the spare.
Rear view camera in the mirror
Spare and camera
Old November 5th, 2019, 12:50
looks good, I just bought a 12" full screen rearview camera to display the video. I considered putting it in the wheel itself, but have as cover over the wheel with storage/ Molle pouches, I didn't want to dive those up.
Old November 5th, 2019, 23:46
richheezee richheezee is offline
Spare and camera
What brand back up camera is that? I have been looking at a lot and have not pulled the trigger. Thanks.
Old November 6th, 2019, 01:03
The camera is an autovox - https://www.amazon.com/gp/product/B01HZM70NU/
Old November 6th, 2019, 09:47
there are a bunch of high quality, 12" , full screen 1440p (2k) mirrors on amazon.
I went with Karsuite
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I went with this one because it came with cameras that use sony sensors, and also had the highest resolution screen I've seen -- 2560x1440, the screen is big, and the video fills the entire screen. Based on youtube reviews I saw, if you tilt your head in a certain way you can still see the mirror. I figured if this really is going to replace the mirror, I want something pretty big with excellent resolution, and high-quality sony cameras. Most rear cameras I've seen are 760p or worse, 640x480.
DMYCO also has a very similar spec'd system-- same sony sensors, same size mirror, same resolution .. and I think same price.
Old November 9th, 2019, 12:54
dropped this rear view camera mirror in, impressed with it -- screen is high quality, camera is excellent (1440p resolution). Only downside is that there's no "off" switch, but it plugs in at the mirror with a standard mini usb, and I may just solder in a micro switch. Here's how the screen looks:
How can I mount a 31" tire on the factory spare tire mount? NCjeepgirl83 Modified Tech Discussion 12 October 1st, 2010 23:16
Hitch and Rear Spare Tire mount for sale Larrythedog SoCal For Sale 4 September 22nd, 2009 20:48
OEM swing away rear spare tire mount with pics ratherbcamping Modified Tech Discussion 6 May 19th, 2008 08:24
Surco 40x50 rack with spare tire mount and hi-lift mount mikeswrangler NAC Classifieds 5 May 20th, 2006 16:42
