Old May 6th, 2004, 15:27
Arakele's Avatar
Arakele Arakele is offline
NAXJA Member #946
AW4/231 to np435/np205 combo
anybody have information regarding this swap
from what i can gather, i can use a bellhousing from a T150, T18 and T176 that was in CJ's originally. just by drilling and tapping 2 holes to work with the trans
which models would i get a slave/clutch etc from?
i know i'll be fabricating a new crossmember/skid plate to accept the new tranny mount as well.
any help is appreciated
Old May 6th, 2004, 16:29
BrettM's Avatar
BrettM BrettM is offline
Re: AW4/231 to np435/np205 combo
what 4.0 are you using now? your flywheel would have to be compatible with both the motors computer and the tranny. do some searching over on http://www.pirate4x4.com/forum , emphasis on search, and use the Newbie Forum if you have any questions because it has been covered before
Old May 6th, 2004, 16:39
Arakele's Avatar
NAXJA Member #946
88 block in a 92, using the 92 flywheel
Old May 9th, 2004, 12:26
Bentonedge Bentonedge is offline
i do nto have any info on going form the 4L to a np435/205. i have 351 and a 435. umm i would say check novak for some info. use google and search for it.
shovel and ax combo? villestrip Non-Tech / Off Topic 8 March 15th, 2004 21:23
aw4/231 or aw4/242 combo or aw4 out of a 4wd model LiquidOps Wanted: Private Party Only 8 January 20th, 2004 07:05
35" tire and wheel combo 5on4.5 Jeepxr400 For Sale: Private Party Only. XJ ITEMS ONLY 4 January 16th, 2004 11:10
different drivetrain combo lengths? (2.5L vs 4.0L) CheapXJ OEM Tech Discussion 0 July 11th, 2003 02:28
Warn Combo Kit Winch Mounting System Miah Modified Tech Discussion 0 June 12th, 2003 14:23
