Old March 7th, 2007, 17:22
white_elephant white_elephant is offline
33x12.50+15x12= i dont know..
will it work??
33x12.50 on rims that are 15x12
Old March 7th, 2007, 17:25
punker248 punker248 is offline
Re: 33x12.50+15x12= i dont know..
If you ever want to run aired down you really risk popping a bead with wheels that wide. 33x12.5 tires run really well on 15x8 rims. a 15x10 is pushing it even.
Old March 7th, 2007, 17:34
mm...so i wont air them down i guess....
or is it to risky??
Old March 7th, 2007, 17:51
CanMan's Avatar
CanMan CanMan is offline
or is it to risky??
Why wouldnt you want to air them down? Sell the 15x12's, get some 15x8's and you will be happy, IMO.
Old March 7th, 2007, 18:25
CHUGLYxj's Avatar
CHUGLYxj CHUGLYxj is offline
x3
not to mention that the 15x12's will give you a huge stance and very little buldge to stop the rim from hitting things.
Old March 7th, 2007, 18:55
Begster's Avatar
Begster Begster is offline
No not really. I know a bunch of people who run 33x12.50 with 15x10 rims aired down without any problems what so ever. You make it sound like he will be blowing a bead every time he is out. I had a pair of 33x12.50 on 15x10s on my jeep last week and they were perfectly fine. A couple of the guys actually suggested that I run that width rim.
I would say ditch the 15x12 and go with a 15x8 or 10. I would prefer the 8's just because, but I would say don't think the 10s are off limits IMO.
Old March 7th, 2007, 19:10
thanks...
anyone want to buy 15x12 wheels?? they are for the d44 of the wagoneer
Old March 8th, 2007, 18:35
DeezUU's Avatar
DeezUU DeezUU is offline
Just goes to show ya... if it isn't done on > it can't be done!!
Old March 8th, 2007, 19:09
Stang5lgt's Avatar
Stang5lgt Stang5lgt is offline
Go with 15x8 the tire will be narrower and less chance of rubbing. Plus less chance of rim rash. I have set of Gambler rims off a TJ 15x8 with 33x12.5. They look good on 15x8 rims. I picked up the rims for 100 bucks.
Old March 8th, 2007, 19:33
Goatman's Avatar
Goatman Goatman is offline
Yeah, like has been said, the 12" rims are way too wide.
Regarding 10" rims......no one I run with will ever run 10" rims again unless they have BIG tires and beadlocks. We've seen and experienced too many 10" rims loosing beads to make it even remotely desireable. If you have them and like them, fine, just be careful airing down low enough for sand or snow, and watch off camber lines in the rocks or slight sideways pulls with the winch. If you don't have 10" rims and are considering getting them.....don't, 8" rims work very well.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old March 10th, 2007, 12:32
DeezUU's Avatar
This is for those people afraid of running 10" wide wheels....
This is a chart for Swamper SSRs (only one I could find on quick notice) and if you take a gander... you'll see that the recommended 'minimum' size for a 33X12.50 is an 8.5 inch wheel. The max is 10". So with that said... you're breaking all the rules by going to an 8" wheel!! hahaha.
I know that an 8" wheel will hold a bead better when aired down but it just looks stupid to me.
(I think it's dead now)
Old March 10th, 2007, 13:02
Darky's Avatar
Darky Darky is offline
A guy asked for opinions, people gave their's and didn't agree with you, why the crusade? I personally would tend to go with what CanMan or Old Man say just since they've been around and are pretty knowledgeable and have lots of experience.
Old March 10th, 2007, 14:20
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Wow. Still running at 30psi in that photo? That's the 50' away shot, let's see how the rims look from closer in? Is that your rig? How'd the front driver's side tire fare in a drop onto it like that?
Old March 10th, 2007, 14:47
BOX BOX is offline
12" wide rim would suck on a 12.5" wide tire... I have 10" wide rims on 13.5" wide tires and last time out... I blew a bead with some pressure on the sidewall going down a tight trail.
in my opinion... if you plan on offroading the vehicle... you MUST go w/ 8" or 9" wide rims
38.5x15-15 BOGGERS on 15x12, 8 lug rims y-townxj For Sale: Private Party Only. XJ ITEMS ONLY 0 December 21st, 2006 23:03
NEEDED ASAP- 15x10 or 15x12 rims xjmudl0ve NAC Classifieds 2 August 28th, 2006 23:17
4 15x12, 5x4.5 polished aluminum rims PavementPounder For Sale: Private Party Only. XJ ITEMS ONLY 0 August 2nd, 2006 06:41
dont know what it is ?? Jimnc OEM Tech Discussion 3 May 29th, 2006 08:31
