Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > WinterFest 2010
WinterFest 2010 Planning and discussion for MWC WinterFest 2010. March 5-7 2010 at Badlands ORP, Attica, IN
  #61
Old October 5th, 2009, 07:25
bmyohn's Avatar
bmyohn bmyohn is offline
Re: The "Hope I get it done by WF Oh-Ten" thread
Originally Posted by FlexdXJ View Post
Bumper is done and I'm ordering my Trackbar, T-case drop and Tie rod within the next couple weeks!
buy me something while your at it!
  #62
Old October 6th, 2009, 02:02
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
Says the guy who's rig is already WAYYYYYYY more built than mine!
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
  #63
Old October 8th, 2009, 06:29
XJ&CHZ4ME's Avatar
XJ&CHZ4ME XJ&CHZ4ME is offline
OK, as if I did not have enough going on at home/farm I have taken on a new project. I am going to pick up this weekend a 21' trailer that is a GN and has a small platform over the tongue. It appears to have beena camper of sorts, or the begining of a project at one time that wa abandoned. It has 2x8 main runners and decent cross bracing as well as brakes on the axles. I am going to do my best to reinforce the frame some more and deck it with 4x8 plate steel and then on the upper deck I am going to put plate steel on it and a small railing around it to haul coolers, tires parts etc. Now for teh grand daddy of the project, i am goingto see if I can mount a pop-up camper sideways across the front of the main deck. I know this was done on Xtreme4x4 blah blah blah, but I am doing it in the means of Xtreme Farm Fabrication The campers are 6'8" and the flat on the trailer is 21', so I should have just enough room on the deck that I can get the XJ and camper mounted up. So, now I need to get it home and start the basic frame supporting and then will move on to decking and then hope to have the camper on it by Winterfest. Wish me luck.....scratch that, I am guided by a force much greater then luck......
Cheeseman-OUT!
Last edited by XJ&CHZ4ME; October 8th, 2009 at 06:30. Reason: f'd up the sizing :D
  #64
Old October 8th, 2009, 10:42
HaleYes's Avatar
HaleYes HaleYes is offline
Yeah, I think I met her at the Pig Gig.
  #65
Old October 8th, 2009, 17:05
XJ&CHZ4ME's Avatar
haha, that you did! She said it has to be done "sooner then later" b/c she does not want an unfinished project "littering up her property"....somehow I am in the rankings of just the gardner around here now...wish I was the "pool boy"
  #66
Old October 10th, 2009, 13:30
XJosh95 XJosh95 is offline
Originally Posted by XJosh95 View Post
My list:
Get the front end fixed...check.
Change front axle shaft u-joints.
Install sliders.
Install tow hooks, again...check.
Weld spare tire carrier to roof rack...check.
Mount up roof rack...check...
Budget boost.
Get All-Terrains or better.
Get shocks...check.
Install D30 diff rock ring.
Get tie rod or my Krusty's track bar...check.
Install said track bar.
Get Oh-10 Cigars ordered.
Now I have to finish up the other items on the list and add a couple more.
Replace fan clutch assembly.
Install mechanical fan shroud.
Install Z34 hood vents.
  #67
Old October 11th, 2009, 21:27
ILLXJ's Avatar
ILLXJ ILLXJ is offline
Get the ZJ HD one, it's only a few dollars more. It's tight getting it in but I think it's well worth it. I'll get a part # for you. JIM.
Originally Posted by monkeyevil
Brian is just a puppet in my corporate empire. I like to give him little tasks to keep him busy and feel important... like talking to Mr. Hale on the phone
  #68
Old October 13th, 2009, 17:33
Jeeperrick's Avatar
Jeeperrick Jeeperrick is offline
I'm going to hate myself for this as it's a lot of work, but...
Making a trip to Iron Rock Off-Road in a few weeks. I just may have a 5.5" long arm kit with me on the way back. Just bought a junkyard Dana 44 out of a waggy...so..
Gears/rear Detroit
rear axle swap
lift
34" LTB's
If I don't do it right away, I'm still fine with my 31" radial swampers and 3" Rough Country lift. I won't take it apart if I can't do it all at once. Sitting out/missing events due to vehicle tear downs sucks!
  #69
Old October 13th, 2009, 17:45
XJ&CHZ4ME's Avatar
Project "try and make junk ass trailer work and look good" has met its demise already. Upon pulling the trailer out of the brush I looked under it more and the main runners/frame have rust holes through them. Not worth the effort to put into this project..so back to the drawing board.
  #70
Old October 13th, 2009, 23:37
ILLXJ's Avatar
NAPA part# 272310. JIM.
  #71
Old October 14th, 2009, 17:18
philagony94xj's Avatar
philagony94xj philagony94xj is offline
I would suggest AGAINST the HD fan assembly. At least the one that sticks out further towards the radiator. Ask me how I know its a bad idea.
  #72
Old October 15th, 2009, 07:25
97XJ2's Avatar
97XJ2 97XJ2 is offline
Or the factory replacement one from napa with the "radiator death tabs" that stick straight out.
1997 2 Door, 4.0L, AW4, NP242 H&T w/ Front DS, D30, locked 8.25" w/ZJ Disks, 4.5" of pieced together lift, 265/75 16's, daily driver with >300k miles.
Don't take it personally, I'm like this to everyone.
  #73
Old October 18th, 2009, 18:12
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Originally Posted by BRIANHO13 View Post
That would be nice, but I will probably try something like linked and rear steered for wf.......
After this weekend the links are looking more likely.......
Old October 21st, 2009, 08:51
REWSTER's Avatar
REWSTER REWSTER is offline
BACON!
just bought a whole new jeep to get done by winter fest
  #75
Old October 21st, 2009, 09:35
XJ&CHZ4ME's Avatar
it can be done...we are finishing a complete XJ makeover for Collin and between it being a stock craptastic rig 2 weeks ago, now it is lifted, has rear disc brakes installed, just received a new paint job and will be getting a few final touches in the coming week. Other then that, a decent build done in 3 weeks. Recruit some good friends and the sky (and your pocket book!) is the limit.....
Rate This Thread:
The Official "My Evaporator Leaked/Leaks" Roll Call Thread TacticalFats OEM Tech Discussion 91 November 23rd, 2012 07:27
Can we get an official "SIERRA CHAPTER EMERGENCY RECOVERY THREAD"? selarep Sierra Chapter 26 April 14th, 2009 16:07
another "volts" thread - pictures - not too large i hope.. cygnus58 OEM Tech Discussion 7 October 27th, 2007 23:45
soon to be 6"(i hope) Ramsey Modified Tech Discussion 8 August 11th, 2004 21:01
