Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old February 19th, 2011, 21:18
P1atinum's Avatar
P1atinum P1atinum is offline
Aerodynamically Challenge
XJ becomes a project
The XJ officially became a project today, The goal for this is to have a pissed off XJ that is still able to take the girls to the beach for Sunday surfing and beach runs.
Plans are First stage – hoping to have this done by mid may
1) Chop the rear and dove tail the rear - I want to take about 3 inches from each side. Then cut down the bottom half of the rear hatch and blend it into the rear to close in the rear, sort of like the guys that have put MJ tailgates on the rear.
2) Take the top half and blend that into the roofline and C pillars – I may take a second hatch and put the whole thing in here but kind of want to leave this mostly open
3) Plate the frame rails
4) Boat side up to the bottom door seals – I want to incorporate HDPE in the sides framed in with 2x2
5) Cage work – not exactly sure what this is going to look like, I am thinking basic internal cage.
6) Hydro assist
Second stage of this build
1) 14bolt rear 60 front
2) Trim to fit 38’s to 40’
3) 4 link the rear
4) 3 link the front
5) Coilovers on all 4 corners
6) Raise the gas tank
7) 4.6 Stroker
A little history
I bought this used and stock several years ago as a weekend off-roader and daily driver, it stopped being a DD about 8 month go. Started gathering parts for the “project” build along with hours and hours of research to decide what I wanted to do with it next.
Through the years
Just after I bought it
31’s and locked F/R
33’ and Rear D44 rear, TNT Ylinks, locked and geared
As it sat this morning
35’s 44’s front and rear, Teralow kit.
The cut- and instantly wondered if I was going the right directions.
That’s it for today.. hopefully get some more work done on Tuesday.
Old February 19th, 2011, 22:14
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: XJ becomes a project
Man, I wish I had the balls! I've been wanting to do EXACTLY what you explained for a long time! The body on mine is beat up more than yours and I still can't make my self bring out the sawzall!!! UGH! I even TRIED to bash mine today while I was wheelin!
Old February 19th, 2011, 22:36
Lowrange2's Avatar
Member# 2368
subscribed, btw.
Do this! I love it and thats what I plan to do.
Old February 20th, 2011, 04:59
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Deja vu...Bills was the exact same XJ before doing exactly what you plan on doing minus the stroker and front coilovers.
Old February 20th, 2011, 05:51
Kaczman Kaczman is offline
Lurker
Originally Posted by lowrange2 View Post
subscribed, btw.
Wow, that's an old pic. Brings back memories.
All fluff, no substance.
Old February 20th, 2011, 06:33
John D's Avatar
John D John D is offline
NAXJA Member # 788
Going to freak a lot of people out cutting a pretty rig like that.
Can't wait to see how it looks in the end.
Old February 20th, 2011, 06:53
RCman's Avatar
RCman RCman is offline
Life is big block
Wow, yet another goes under the knife.
Good luck, it is a lot of work and those are some pretty ambitious 2nd stage goals!
Old February 20th, 2011, 11:38
P1atinum's Avatar
It took quite a bit for me to make the first cut on it, my wife kept asking me why I want to “junk it up” I just look at her and smile
The project is pretty ambitious as it stands, If I get 50% of what I am planning done in the calendar year I will be happy.
I am taking a lot of my ideas from Bills build yours turned out really clean and well built. (taking ideas from the rear hatch mold in, some of the cage work, front hoops, Exhaust routing and rear cross member (BTW RCman I saw you broke the rear upper link mount but didn’t catch what you did to fix it I will need to hit you up a couple of times when the time comes)
Old February 20th, 2011, 14:38
Lowrange2's Avatar
Member# 2368
Man, I love that thing. I wish I had more pictures of the build, mostly of the structure of the back end. I've got maybe 5 pics of it. That's exactly what I want to do.
Old February 20th, 2011, 14:39
Lowrange2's Avatar
Member# 2368
Lol, my girl kept helping me find ways to bash it in so I would cut it. I just need to roll it.
Old February 20th, 2011, 15:12
RCman's Avatar
Life is big block
Haha, I know that feeling!
I did, 2nd trip out. It was because I didn't have enough bracing on it and the metal fatigued and tore. I was trying to get it done and neglected to add some support to the upper frame side mounts. The issue has long since been fixed with a bunch more steel. The entire underside was plated and two additional gussets were added. Definitely not anywhere now. I really don't have a rear crossmember, the lowers tie in similar to the uppers and the B-Pillar X drops down onto the top of them.
Shot of the now fixed/supported uppers:
Old February 20th, 2011, 16:48
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Wow, another one gets abbused by the sawzall!
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old February 22nd, 2011, 04:59
foxwar71 foxwar71 is offline
Projects are fun!!
Im looking forward to seeing what you do with the rear bodywork.
Old March 10th, 2011, 15:06
P1atinum's Avatar
Updates,
Not as much done today as I would have liked with crappy weather this morning.. But it gave me a chance to pick up these....
39.5's anyone. Scored a set of 39.5 Pitbull Rockers for almost nothing.. 2 are about 50% and two are pretty worn but I couldn't pass them up.. I will try and pick up some 17" wheels this weekend and mount them.. I will need to stretch the rear axle back about 4" and open up the wheel well and push the front out about 2" and remove the two "humps" in the front of the fender to use them offroad. that means relocating the Battery in the rear as well.
I did get the rear hatch to fit pretty well and where I want it. I really tried to get it as far forward as I could so I can still come through the floor with the Coilovers. which I hope should be here next week..
Next is the tailgate and order some Tube.
More to come tomorrow.
Old March 10th, 2011, 16:39
Timmy2XJS's Avatar
Timmy2XJS Timmy2XJS is offline
thats one sweet looking rig man
Rate This Thread:
new tow pig project 256offroad South East Chapter 13 August 19th, 2009 07:52
Project 100$XJ and Project JEEPSPEED AZXJ Arizona Chapter 23 August 23rd, 2007 12:57
91 4dr project 33s, 91 4 dr project stock Rockhound For Sale: Private Party Only. XJ ITEMS ONLY 1 May 8th, 2007 20:13
New Project, PC XJ langer1 Modified Tech Discussion 64 December 4th, 2006 20:45
got me a project imma honky Non-Tech / Off Topic 0 June 14th, 2004 13:10
