Intake manifold upgrade - serpentine routing/size?
Puddin99
Scappoose, OR
I just upgraded my 94 4.0 Cherokee (pretty much stock, 5spd w/ac) with a newer intake manifold. At the same time put on a new exhast manifold - that wasn't cracked. I purchased a newer compatible power steering braker off of ebay to go with it. Everything went together pretty good. My question is, the original belt won't fit - didn't expect it to. I've read all of the other posts, before after and during...didn't see any real positive information about what one should do about rerouting the belt with the new mount - including the new adjuster and what might be the size of the new belt.
Any help appreciated.
Thanks,
Ken
I removed the stock fan and pulley. I also needed a different belt size. I took a string and went through all the pulleys as the belt pattern would go. Took the measurement off the sting and off to the part store I went. Save yourself time and take in the old belt to match up ribbing and measure it in both standard and metric.
