xcm
- Southern Oregon
seeming as how allmost every d30 build posted is oriented towards rock crawling, i thought i'd post a question to minds in the know...
how would you build a d30 for speed? obviously some kind of truss.... but are alloy shafts/upgraded ujoints needed for the occasional hill climb?
the way i see it at this point, i can afford full truss work OR alloys, not both...
obviously, im trying to keep this cheap, not for budget reasons, but rather the 'shoulda built a 44' reason... if i must drop $1500, it should be for a 44.
but im tired of 2wd sinse swapping in a 4.56 d44 rear.
final question, non disco d30 + aussie in a np231 part time xj that originally had a vacuum disco... any problems? i'll need a new driveshaft right? (sinse mine was originally un-balanced at hi speeds)
what about the JK d44 front? has it seen desert time yet?
thanks
thanks
