Old March 17th, 2008, 04:36
terryd's Avatar
terryd terryd is offline
Front reciever, D-ring tabs, or both?
Well, I've finally gathered the materials for my front tow points. I'm using plates that incorporate the steering box and factory bumper bolts on the sides, with a piece of angle iron on the inside of the two tabs on the front of the body where the bumper bolts up and a piece of 2.5"x2.5"x.250" box between them behind the front bumper.
Now I'm trying to decide whether I should poke two d-ring tabs through the bumper between the factory bumperettes or trim the bumper a little in the middle below my license plate and put a 2" receiver tube there, or just do both.
Here's a quick sketch of roughly where they would come through the factory bumper.
Old March 17th, 2008, 05:14
wiretie's Avatar
wiretie wiretie is offline
NAXJA Member # 1664
Re: Front reciever, D-ring tabs, or both?
IMO if an aftermarket bumper isn't in your price range, I would say both. It'll give you more recovery options.
Old March 17th, 2008, 08:38
600dollarxj 600dollarxj is offline
Yeah, if you're building it why not do both. They're both pretty easy to make, and they're both good recovery. If I was going to do just one I would probably do d-ring tabs.
Old March 17th, 2008, 08:50
SnagglePuss's Avatar
SnagglePuss SnagglePuss is offline
Pretty happy with this purchase. Not too much $$ and good quality.
http://www.nates4x4.com/catalog/prod...products_id=37
Old March 17th, 2008, 09:02
ehall's Avatar
ehall ehall is offline
I'm planning to weld some 2" class-III receivers to tow-hook brackets. Then I can use the inserts to run shackles, hooks, or even flat tow the Jeep using a tow-bar, whatever I want. If done right, the receivers will come out through the air deflector under the bumper and be pretty well hidden.
Old March 17th, 2008, 19:43
strikedistance's Avatar
strikedistance strikedistance is offline
I would say get this. But thats just me.
http://www.detoursusa.com/xjbackbone.php
Old March 17th, 2008, 20:20
badron badron is offline
I would do the receiver tube or both. The receiver besides good for recovery point. Can also be fitted with a winch, a platform, a chair.
D-Ring Tabs dgrigorenko Modified Tech Discussion 2 January 19th, 2008 18:49
Tow bar to D-ring tabs bl87xj Modified Tech Discussion 3 August 21st, 2007 09:23
good price on d-ring recovery reciever? alwaysready Midwest Chapter 0 June 19th, 2007 13:56
Attaching front tabs to custom bumper xj92 Modified Tech Discussion 2 September 21st, 2004 18:02
NORCAL: BPIfab Rear bumper, tire carrier, hitch, D-ring tabs $600 - '96 and OLDER basalt51 For Sale: Private Party Only. XJ ITEMS ONLY 14 November 24th, 2003 15:25
