Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter > SEC - Trip Planning Forum
SEC - Trip Planning Forum A place to organize trips within the Chapter
Old April 12th, 2017, 07:29
SavedDad SavedDad is offline
Uwharrie 4/15
first run with my 95.. should pull into the outpost around 10:30 am! woohoo
Old April 13th, 2017, 07:47
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Re: Uwharrie 4/15
Unfortunately I have some house repair work I need to do Saturday.......
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old April 15th, 2017, 05:23
Re: Uwharrie 4/15
Hour #3 the xj died...was running great...engine was strong...and then....nothing. I forgot to turn my electric fan back on. We sat on the trail with the fan on...it cooled enough to continue....1/4 mile away...and it just cut off....checked for fuel at the rail....yup...the ground was loose...still won't start...checked all the fuses....still no fire...30 min later..."I'm gonna try one more time"...yup it started and was just as strong as before... any suggestions to check now that I have it back at the shop?
Sent from my SM-G928V using Tapatalk
Old April 16th, 2017, 12:01
Ghost's Avatar
Member Number 257
Re: Uwharrie 4/15
Crank sensor will fail when hot before they fail completely some times.
Old April 16th, 2017, 14:24
Re: Uwharrie 4/15
Perfect...easy replacement?
Old April 16th, 2017, 14:27
Ghost's Avatar
Member Number 257
Re: Uwharrie 4/15
It's on the top driver side of the transmission bell housing. It's not too bad. Might not be your issue though. The coil will do the same thing. I'd check for a crack in the coil too.
Old April 16th, 2017, 14:29
Re: Uwharrie 4/15
Can you help with another problem...xj did fantastic...low range would not stay engaged...any ideas?
Old April 16th, 2017, 14:32
Ghost's Avatar
Member Number 257
Re: Uwharrie 4/15
Yes I would guess it could be the shift fork pads. They are plastic and wear out. Could be the shift mechanism in the transfercase too. Either way it would need to be opened up and inspected. At least that is where I'd start.
Old April 16th, 2017, 15:10
akendal4's Avatar
akendal4 akendal4 is offline
Re: Uwharrie 4/15
CPS is a good start for the engine shutting down.
As for the TC, do you have a TC drop? I'd start with adjusting linkages before opening the case to check the fork pads.
Old April 16th, 2017, 15:13
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
Re: Uwharrie 4/15
When it shuts off, pour a bottle of water down the back of the engine on the CPS. If it starts, you know where the problem is.
I have 36" of extensions and a spare CPS in my trail kit.
Old April 16th, 2017, 15:38
Ghost's Avatar
Member Number 257
Re: Uwharrie 4/15
Good point.
Never thought about that.
Old April 16th, 2017, 19:02
92_beater 92_beater is offline
Re: Uwharrie 4/15
If I actually paid attention I would have wheeled with you, holler the next time you go, or if your local just holler if you get stuck on some wrenching
Sent from my SM-G935V using Tapatalk
Rate This Thread:
Uwharrie on 8-11-07 hotrod22 South East Chapter 3 August 8th, 2007 09:37
Uwharrie run XJ FREAK South East Chapter 22 November 27th, 2006 04:45
Uwharrie HoodRichXJ South East Chapter 0 September 27th, 2004 08:10
Uwharrie CHNSTRAP Competition and Events Forum 2 November 11th, 2003 12:41
Uwharrie 12-7? woody South East Chapter 3 December 9th, 2002 06:43
