Spartan Locker Dana 30 ONLY $220 FOR A LIMITED TIME ONLY
For a limited Time only.
Spartan Locker for the Dana 30. The strongest, easiest to install, and only insert locker to include a hardened cross shaft and new roll pin. $220 Use coupon code RWKSPARTAN The Spartan Locker, by USA Standard Gear, provides reliable traction at a low cost. Give your vehicle great traction and save some cash. Choose a Spartan Locker for better traction. The Spartan locker by USA standard gear is a mechanical locker that replaces the spiders in a standard case. The Spartan locker's design does not use the thrust washers and has a revolutionary spring and pin design that makes installation a snap! The couplers and drivers are made from 9310 steel, for added strength. Each Spartan locker carries a one year warranty against defect. •Fits Dana Spicer 30 with 27 spline axles •Made from 9310 steel for added strength •Replaces the spiders in a standard carrier case RWK Haus Supply Robert@rwkhaussupply.com 714-875-2414 www.RWKHausSupply.com ![]()
RWK Haus Supply All your drivetrain And Jeep needs at a Discount! Call us for all your drivetrain & Jeep accessorry needs. If it is for a Jeep we can get it for less and with superior service. Yukon, USA Standard, Motive, Ten factory, Detroit, ARB, Teraflex, Rock Krawler & A LOT MORE.. All items ship FAST! ~ http://www.rwkhaussupply.com ~ Robert@RWKHausSupply.com Free shipping on Rock Krawler kits. Dana 30 no question asked 1yr warranty axle kits FOR LESS!
#2
Re: Spartan Locker Dana 30 ONLY $220 FOR A LIMITED TIME ONLY
So this will fit a d30 with disconnect, yes?
Gravity is a fickle mistress. Ethan: "What did you think would happen?" '01 XJ • 4.0 • AW4 • 231 • Modified '87 MJ • 4.0 • AW4 • 231 • Stock-ish SoCal Chapter Past President
#3
Yes.
#4
Email sent.
Thread Tools | |
Display Modes | Rate This Thread |
Limited Time Special: Front Dana 30 Locker and 4340 axle kit - $599 | RWKHausSupply | Vendor's Specials | 0 | July 9th, 2018 14:41 |
Air Lockers Limited time only! Dana 30 & 44 -Free gear set w/Air locker & $100 Rebate | RWKHausSupply | Vendor's Specials | 5 | March 7th, 2016 09:02 |
Limited Time! Lock-Right locker Dana 30 $220!!!! | RustysOffroad | Vendor's Specials | 16 | March 21st, 2013 12:35 |
Dana 30 spartan locker - $235 shipped! Limited time! | RWKHausSupply | Vendor's Specials | 4 | December 5th, 2011 19:51 |
Dana 30 Eaton E-Locker 30 Spline - 725$ to your Door - Limited Time... | RWKHausSupply | Vendor's Specials | 0 | October 14th, 2010 10:36 |
