Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
  #796
Old July 25th, 2017, 14:56
ftwelder's Avatar
ftwelder ftwelder is offline
Re: Ross's Jeep that will take longer than Rob's to build thread...
Originally Posted by foxwar71 View Post
Shush.
For once, I'm gunna attempt to lose weight with this rebuild. Maybe if it's not a fat pig, it won't dent as easy.
That works for me..
Old July 27th, 2017, 00:18
BasslicksXJ's Avatar
BasslicksXJ BasslicksXJ is offline
Awesome build man.... sub'ing for updates.
Old July 29th, 2017, 03:39
foxwar71 foxwar71 is offline
Keep cutting, keep guessing!! Still not sure how the link crossmember is gunna play out but I have a plan for the UCAs.
Old July 29th, 2017, 15:53
ftwelder's Avatar
I put a 2X4 cross member at the B pillar and top of the frame rails. May be that would line up with the ends of the cage tubes?
Old July 31st, 2017, 10:49
COjeeper COjeeper is offline
Looking good man. Following along as I plan on doing something similar.
Old August 7th, 2017, 16:51
Sure, let's do this! Ordered the rest of the parts I need to get the rear end mocked up and cycle stuff. I think I'm just gonna cut my existing shock hoops and build new ones, time will tell.
Old August 15th, 2017, 06:15
Bunch of little things like misalignment spacers for the coilovers, pinion guard/truss tie, and LCA brackets came in Friday/Saturday so I spent Sunday getting everything mocked up and started to cycle the suspension.
Old August 15th, 2017, 12:15
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
I'd be real interested in what spring rates you end up with on the rear. What travel are those? Sway a way?
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old August 15th, 2017, 14:26
2.0x14 Swayaway Racerunners, I'm thinking like a 200/250. Bill (RCman) had the same coilovers with 150/250 and he said he wished he had a little stiffer. Once the Jeep is all setup, I'll weigh it and get all the corners weights
Old August 16th, 2017, 04:48
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Do the math and get the correct spring rate. Soft enough to hold the weight and then valve it correctly.
Old August 16th, 2017, 08:54
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
x2. get your dampening from the shock, not the spring.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old August 22nd, 2017, 17:50
RCman's Avatar
RCman RCman is offline
Life is big block
Looking good!
2.0x14 Swayaway Racerunners, I'm thinking like a 200/250. Bill (RCman) had the same coilovers with 150/250 and he said he wished he had a little softer. Once the Jeep is all setup, I'll weigh it and get all the corners weights
FIFY.
Mainly it was the transition to the 2nd stage that was a bit harsh at speed. Crawling was fine.
X3. Especially if you buy your own Nitrogen fill kit like you texted me about. Valving does not take that long and the shims are cheap.
Takes a little work but way worth the effort.
Old August 25th, 2017, 17:01
Old October 17th, 2017, 19:05
TheDanShin TheDanShin is offline
so much room for activities! great idea dude
Old October 22nd, 2017, 17:43
Rate This Thread:
Minecraft Jeep - Build Thread Alexia Modified Tech Discussion 79 May 12th, 2012 19:25
THe NAC lots-o-rob's-birthday thread Dundy North Atlantic Chapter 28 January 10th, 2011 12:08
New Jeep Repair/Build thread DanMan2k06 OEM Tech Discussion 36 August 2nd, 2010 19:31
My New (to me) Jeep build thread maxxpehling NorthWest Chapter 15 March 24th, 2009 22:08
my 89' cheep jeep build thread... KentuckyXJ Modified Tech Discussion 11 February 16th, 2009 19:26
