Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
  #8491
Old March 23rd, 2020, 07:54
#3misfire #3misfire is offline
What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Originally Posted by Hellphenix View Post
This is not for me? Iím having a draw I think from my coil.
My only motive for doing this was to eliminate suspicion about a misfire I had.
Old March 23rd, 2020, 08:02
Hellphenix Hellphenix is offline
Re: What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Ok. Iíll have to tool around then. I did my wires to copper 2-4g and did connect the coil wire until I realized that when I changed my altinater to a 136amp and it was dead this morning after sitting the weekend. It has a draw before I did the wires and plugs,wires,cap,rotor,coil. No misfire though.
Old March 23rd, 2020, 08:07
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
No. This is for the later coil on plug system.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old March 23rd, 2020, 08:22
Copy that. Just did some looking up and came to the same conclusion. Thanks for your time.
Old April 29th, 2020, 09:53
OkieXJ's Avatar
OkieXJ OkieXJ is offline
Finally got my 8.8 back in after attempting to set up my own gears. I thought the pattern looked perfect but that are noisy as hell. I'm going to take it to someone to have the front gears done and a locker installed and I'm going to have them redo the back ones while they're at it. Just posted in modified tech about the front locker. Apparently Eaton discontinued the dana 30 e locker and has a new part number and now availability is scarce. That would happen when I'm finally ready to pull the trigger after years of waiting...
'91 Laredo 4.5" lift underway, 16" Moabs w/ Duratracks, Conn-Ferr rack, C4x4 front bumper, APN header, EBC pads and rotors, 8.8 swap, AA SYE & Tom Woods driveshaft.
'87 MJ with no drivetrain
Old May 29th, 2020, 17:12
devildog0's Avatar
devildog0 devildog0 is offline
Old school XJs aren't exactly known for their abundant power oulets so I added a low profile USB port into the passenger side cubby to power the nav tablet and give my wife a place to charge things when she goes with me.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old May 30th, 2020, 07:24
devildog0's Avatar
This morning I got up cause the dogs wouldnt stop barking and decied to go clean up my center console secondary radio spot install. I routed the SAE connector in and slapped a grommet on it, this will power up any of my radios. Then put all the APRS stuff in there and Routed all the cabling for that and stowed it behind the rear support for the console.
Sent from my SM-G892A using Tapatalk
Old June 3rd, 2020, 06:57
Crusher16's Avatar
Crusher16 Crusher16 is offline
RRC President
I installed my Boostwerks Tcase shift linkage finally. Still having issues popping it into 4lo, so I see another tcase rebuild in my future.
1991 Briarwood
4 inches of upness | 4.56s | 33x12.50 KM2s | 8.25 with Disk Brakes | JKS HD XMember | JCR Front Bumper & Sliders | AJs Offroad Tanker Rear Bumper | NP242 - IRO HackNTap | Ironman4x4Fab UCAs & LCAs | Bilstein 5125s
Old June 26th, 2020, 08:32
devildog0's Avatar
Trying to track down a small exhaust leak on the XJ. Only hear it under heavy load. Found the junction for the header and downpipe to be loose so replaced the studs/nuts and put in a new donut gasket there.
I have been having a rattling in the front end for a while as well. I have been writing it off as a loose brake dust shield but when I was under there dealing with the exhaust gasket I found the driver's control arm loose and when I looked closer found both the bushings on that control arm had backed out from their bores and were just kind of floating in the control arm.
After I finished up the exhaust issue I pulled the control arm and took them to press them back in and found the control arm bores are now oversized. So I tack welded the bushings to the control arms for a temp fix and ordered some 2004 Grand Cherokee lower control arms.
Old June 27th, 2020, 11:06
devildog0's Avatar
Replaced lower control arms video above. My ride is better much better with the GC control arms but I'm not sure if that's because the GC arms are so much better or because I'm no longer rolling around on wallowed out bushing bores.
Then even after replacing the header/downpipe gasket I'm still getting an exhaust leak. Checked torque on all the header/intake bolts and found none loose so I'll be hooking up the smoke tester today and seeing if I can find the leak that way. I'm thinking at this point I'm going to find a crack in the header so got a new one added to my Rock Auto cart on standby for check out.
Rate This Thread:
What was done to your rig today? A7XJ Arizona Chapter 1781 March 26th, 2016 21:13
In serious need of some help today. DrMoab Intermountain Chapter 16 November 30th, 2010 20:52
Tried out the TSL's today TheInstaller Jeep Picture Showcase 12 May 7th, 2007 22:16
new 37's came today!!! atowley Modified Tech Discussion 17 February 23rd, 2004 09:02
