Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > NorthWest Chapter
NorthWest Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old November 4th, 2019, 20:15
Greenz's Avatar
Greenz Greenz is offline
Re: What did you do to your XJ today
Got started on the drum to disk conversion.
Out with the old. I knew the right rear wheel cylinder failed and I discovered the left was weeping brake fluid. Had forgotten until going inside the drums, I had replaced the shoes and hardware not too long ago. All the shoes on both sides were oil soaked.
Cleaned off tons of rust left over from the early years when the XJ lived in the Midwest. Bearings looked fine. New seals. Longer backing plate studs from the donor installed.
Dust covers were bent from the rough handling in the junk yard. It was easy to straighten. Donor parts looked good not much wear and hardware wasn't rusted out so I reused everything. Oh, grinding the backing plate centers was not fun, took longer than I thought.
Tried the original wheel studs with the lug nuts. Three and a half turns was not making me feel very comfortable. Replaced them with Dorman 610-290. They are the only ones with the same knurl diameter with a longer length. Was concerned with the little nub but my acorn security nut fit without bottoming out. Didn't buy the press for this job but it made this swapping the studs easy.
Hope to finish tomorrow.
Old November 4th, 2019, 20:53
xeroOTG's Avatar
xeroOTG xeroOTG is offline
That looks great man! I love my KJ rear discs.
Sent from my Pixel 3 using Tapatalk
Proof I've spent all of my money on my Jeep: John's 98 Build Thread
Old November 5th, 2019, 20:40
Greenz's Avatar
Thank you Xero. It's good to hear positive remarks on the KJ brakes. Some have said they can't tell a difference. We'll see!
Getting there. Set the disks with nuts to pre adjust the parking brake shoes. Had to do it again later. Oh well. This is how I measured my current nuts on the longer studs.
Made my own hose brackets. Found another use for 4 degree shims. lol BTW, I'm getting the swag finger brake. Until then, this janky setup actually worked.
Brackets installed. Not the best setup but everything is secure and out of the way. Plus, now I have two spare lug nuts.
Last picture. It got dark on me so I couldn't get any more. Swapped the proportion valve, tightened two leaks, and finally bled everything. Used the ZJ parking cable on the D side, stock with a clamp on P side. Adjusted parking brakes and went for a ride. They settled in nicely. Brakes are smooth and vibration free. Junkyard rotors, calipers, and pads were just fine. Overall it was a fun project but took longer than I wanted. The weather played nice. Brakes work great. First time I have been able to stand on the brakes and lock up all four tires.
Old November 14th, 2019, 03:56
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Looks good, got any pics of the parking brake mounted?
Old November 14th, 2019, 06:39
Greenz's Avatar
I can get you a picture in a few days.
I used the 95 ZJ on drivers side which fits nicely. Passenger side is the stock XJ cable modified with the cable clamp. I don't like the way it looks but it works. Will continue to find a better solution. deesexj sent a link to G2 site but I haven't looked into it yet. This setup is awesome!
Old January 15th, 2020, 18:09
spidermikey88's Avatar
spidermikey88 spidermikey88 is offline
Got a set of 33" tires from a co-worker and threw those on and adjusted my shackles to lower the rear end a little to level the Jeep out.
Then I adjusted the toe inward because it was visually toed out and I was getting some crazy bump steer and it was pulling hard to the right. I dunno if it had always been toed out that bad but I never had any issues with my old 31's. Tape measure method said I was 2" out. Got it within 1/8 inward now. It was my first time doing this do I hope I did it right and it is steering much better now.
Also replaced my coolant hoses and the resivour again :/ when this one cracks, I will probably swap to an aluminum one. (Original res with just a small leak in pic, new replacement is in the mail)
Sent from my Pixel 3a using Tapatalk
Old January 27th, 2020, 15:25
Finally got around to installing the ZJ tierod and draglink+new TRE's that I have had sitting around for a year or two. Steering is much tighter now.
Old January 30th, 2020, 03:57
PCO616 PCO616 is offline
I shot some Krown T40 rustproofing oil into the rear corners of my XJ. I had it sprayed in November but I like to add some when I can.
Old February 22nd, 2020, 09:23
TORX's Avatar
TORX TORX is offline
NWC President
Guess I need to update the build thread, winter changes underway...
Old February 25th, 2020, 10:34
Replaced stereo, rear hatch struts, started working on my rear interior panels again and ordered a Detours knucklebone offset tire carrier. It'll be nice to get the spare out of the back. Also found a lot of rust under the passenger floorboard :/ so that'll need to be addressed eventually.
Old February 25th, 2020, 17:31
#3misfire #3misfire is offline
Did some armor the other day, itíll all get color matched with linex, a trailer light harness from curt, and some new led bulbs to replace the burned out junk. Next days off Iím putting on hood spacers and a viper coil from k suspension.
Old February 25th, 2020, 18:42
BigNuge's Avatar
BigNuge BigNuge is offline
Thatís a nice XJ! I want to add armor to mine as well, but need to do 2x6 tubing rockers first.
I like the lower portion of the doors painted black like that, I might do something like that...
BigNuge's 99 XJ Build
Old February 25th, 2020, 18:57
Thanks man! All the black you see is armor. Iím gonna color match it all except the lower rear. I really really liked the clean look but I had some dents in the lower door that needed covering up so I opted for armor. Shit is pretty heavy too, I can feel the weight of it after install.
2x6 rockers would be sick but thatís a ways out of my wheelhouse.
Old February 27th, 2020, 12:52
BigNuge's Avatar
I almost went with red D-Rings too...lol. I ended up going with plain black.
Old February 28th, 2020, 14:30
Looks badass
Today.... Jump This SoCal Chapter 13 October 22nd, 2008 00:53
Sad Day Today. Jays siik xj SoCal Chapter 20 May 21st, 2008 13:08
Today... Jump This SoCal Chapter 22 April 9th, 2008 22:23
40 today huh? DrMoab Intermountain Chapter 15 May 5th, 2005 16:34
took my NET today... BUCKYXJ Non-Tech / Off Topic 8 February 8th, 2005 16:20
