Lowrange2
- Abbeville, SC
I was just going to refer you to Will's thread but it looks like you found it.
I need to come see you, saw your craigslist ad the other day...looking for wheels
Front Driveshaft that is servicable. All I need is a core that I can lengthen to 32"
I need a air intake tube and that hose that goes from the air box to the valve cover.
got my parts over the weekend. thank you sir!
I've sold the harness from this 99 already. I have a harness from a 98 if that'll work for you. To my knowledge, the only difference is the sensors on the throttle body.
I have currently tried to use a 98 harness in a 99. I've found no difference with the throttle body, but the oil pressure sending unit is different. The 98 model is 2 wires while the 99 is 3. With the 98 harness I get no reading on my gauge.
Thank you!
