Old June 14th, 2011, 20:19
ADVNTURR's Avatar
ADVNTURR ADVNTURR is offline
I worry when rattles stop
Safe storage of a gas tank while out of the Jeep??
I am in the process of starting some major repairs/upgrades to my 91 and I have removed the gas tank so that I can do some welding in that area. I have most of the fuel out of the tank but there is still a little bit in it along with the fumes. Does anyone have any suggestions on what to do with the tank to keep it from being a fire hazard? Should I just cap the filler and vent bungs? If so, with what? Any ideas would be appreciated.
I've unfortunately already had a bad experience with fuel and flames and I'd rather error on the side of caution.
Old June 14th, 2011, 21:06
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
Re: Safe storage of a gas tank while out of the Jeep??
Err on the side of caution. It needs to vent, so capping it tight is a bad idea.
Keep it away from sources of ignition and heat.
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old June 14th, 2011, 22:31
5-90's Avatar
5-90 5-90 is offline
Empty the tank.
Remove the filler neck line and the fuel pump mounting access
Blow the tank out with compressed air, having one of the ports being the lowest point of the tank (fuel vapours are heavier than air, as I recall.)
Blow it out until you can't smell fuel anymore.
Set it aside, leave it open.
Recall that fuel vapours are very nearly explosive - which is why I store fuel cans (when empty) uncapped - and leave them upside down at first, so the fuel vapours drain out.
Ever hear of a "fuel-air bomb" or "fuel-air explosive?" Look it up - they're very effective in enclosed areas for antipersonnel...
oba storage tank 4wdParakeet Modified Tech Discussion 3 August 19th, 2008 08:45
Rear Cargo Area and CO2 Tank Storage AnzaJeep Modified Tech Discussion 13 May 5th, 2008 09:46
Is my jeep safe to tow with ? camarors8992 OEM Tech Discussion 1 October 6th, 2006 04:32
vac. storage tank? mike harris OEM Tech Discussion 5 July 13th, 2004 19:53
rear bumper/air storage tank?'s chad Modified Tech Discussion 3 November 4th, 2003 19:51
