crazycracka
- The OC, Oregon
So I posted on here months ago about my Transmission acting weird. In 1-2 selection it would stay in first and not shift to 2nd. In 3 selection it would shift into 4th gear instead of stopping at 3rd. In OD it would shift into OD at like 35 and would have to almost floor it to get it out of OD.
Anyways I never got any clear answers on why it would do that. I did some searching and came across a posting on adjusting the TV Cable(Throttle Valve). So today opened the hood took 2 seconds and it was done. Drove it around the block and WOW night and day. 1-2 works 3 works and it doesn't stay in OD. Push on the pedal just a little and it smoothly shifts down.
So anyone that hasn't checked/adjusted the cable or anyone that is having weird tranny problems Adjust that cable first.
How to from Alldata:
1. Shift transmission into Park, shut engine off and raise hood.
2. Press cable release button.
3.Push cable conduit back into cable sheath as far as possible.
4.Rotate lever on throttle body to wide open throttle position. Cable will ratchet to correct adjustment point as lever is rotated.
Super easy and worth checking. Sorry if this is in the wrong area.
