Looking for a ZJ prop valve
Nuke Proof
I've been looking for a couple of weeks now and cannot find one anywhere. Does anyone know of a parts dealer or wrecking yard that might have a line on one? Or does anyone know of another way to have a rear disc brakes on an 89 XJ without dragging the rear calipers? Any help would be appreciated.
Thanks
As far as I have been able to tell, the ZJ prop valve is no major upgrade if any at all.
If your rear brakes are dragging, I'd look for a problem the same way you would if your drums had been dragging - bad caliper, pinched brake line, etc.
There's a couple ZJs in my local PnP
Billy
I spoke with Cal pretty extensively and it looks like my best option is to do what Jess suggested. My only problem I have now is finding a WJ MC and booster for a reasonable price. I found one at a couple of JY's, but one was $150 and the other was $115 for the MC and booster.
I'll keep checking, but I called about a dozen today and only those two had one in stock.
Thanks again guys
Darin
AS for the P-value goes. Any disk/disk P-value will work. Some are easier to bolt up that about it. The guts for a ZJ P-value MAY slide right in. This has work for some. Making the install super easy.
Removing the O ring works for many but you lose your independent systems that way. If it maters. The rear may lockup a bit sooner to. But big tires will hide this for the most part. I asume you running big tires anyway hence the need for more braking.
How many people actually have found swapping p-valves helps them?
I have a ZJ booster/MC and didn't need to touch my stock XJ p-valve. I have no problems with the rear brakes dragging at all last time I checked.
Changing of the P-value is for the disk/disk conversion. The P-value cares little about what booster (if any) or MC is in use.
Few will ever FELL any change. But using a disk/drum P-value on a disk/disk system may permit the rear disk to engage before the fronts. With stock or near stock tires the wrong P-value may show up as early rear lockup. Even more promoted then the stock setup.
But most XJ that do the disk/disk conversion do so because of much larger tires. The larger tires tend to prevent lockup. The most they will see is MAYBE rear pads wearing faster then the front.
Also many XJ run with tons of heavy junk in the trunk. Spare axles big tool boxes beer etc etc. In there case the "wrong" P-value may proved a better front to back braking bias for there load.
Truly even braking is a balancing act. That few ever see or care about as long as they stop before they hit the tree,
All this is (IMO)
Where is a good place to locate a WJ MC and booster? If anyone has a line, please let me know.
if your still looking for the wj set-up, i went to car-parts.com and found a local junk yard that had it. went down to junkyard to pay for it(65$ for the booster and master) as they wont pull it off until you pay. 30 minutes later i was out of there with the parts i needed. bought a double flaring kit and some brake lines and installed it. night and day difference on my 89(still have the 10" drums on the rear).
Thanks, I keep forgeting about car-parts.com.
As far as the prop valve is concerned. After speaking with Cal pretty extensively, I am going to leave the XJ one in.
Thanks again
Does it matter what options the WJ has? Or will any master out of a 99 and newer Grand Cher work?
When I first did my rear disc swap I ran the original prop valve for a while (this is on a '96 btw so, I already had the better booster) and it stopped ok (not great). I went to a Jeep only wrecking yard and picked up a ZJ valve for about $30 and just swapped the guts (much easier than swapping valves as the ZJ valve has a different mounting bracket) and it did indeed stop much better........discs require more pressure than drums (which are self energizing) so, using a prop valve that's metered for drums won't give full pressure to your new rear discs and most of the stopping will be done by the fronts............I would do the swap-----------Hans
Does it matter what options the WJ has (i.e. motor, trans, t case) or will any 99 and newer grand cherokee work? The reason I ask is there is one yard that has one for $225 and another has one for $75. The only reason for the drastic price difference that I can think of is there are different MC's for different options, or one yard is just greedy.
Thanks
The WJ booster/mc setup is the same thru 99-04. IIRC it doesn't matter if the WJ was 6cyl or V8. FWIW I just got mine from a jy down here for $100.
I looked into doing that same thing, but the XJ and ZJ had the same part number for the prop valve.
How much of the difference is just butt dyno?
XJ on left, ZJ on right.
The springs are different lengths, the plunger/endcap also has a different diameter.
Interesting.
How different are the plungers/endcaps? Could one get away with triimming a loop off of the spring?
