Prepmech NAXJA Member #981 Location Neoga/Decatur, IL Feb 25, 2007 #1 Got bored the other day so decided to work on the hood a little bit.
aparke4 NAXJA Forum User Location Atlanta, Ga Feb 25, 2007 #2 cool did you simply cut and raise and then tack in new pieces for the sides?
Prepmech NAXJA Member #981 Location Neoga/Decatur, IL Feb 26, 2007 #3 aparke4 said: cool did you simply cut and raise and then tack in new pieces for the sides? Click to expand... Yeah, made two cuts on each side in a triangle (wide part towards back) so that the sides are slanted at angles. Also had to support the middle at the crossmember to help keep it from flexing.
